cosworth tca's
Pete,
I was of the understanding that 4x4 ones have parallel studs that clamp in the hub knuckle (this is definitely true), whereas 2wd ones have a tapered stud and retaining nut on the top...
They are possibly a different length too (different crossmembers)..
4x4 ones are twice the price of 2wd ones, so I hope there's a difference
Originally Posted by Eagle
ERMMMM yeah they are shorter... but not a problem im sure they can be bodged
oh and thanks to sleeping beauty ..... will let you know if i find any other bits for ya ryan
4x4's are indeed different where they clamp into the hub
Wouldnt be at all suprised if they are different lengths too due to the differences in offset etc
Neil.
Really?
From what I have seen, 2wd's have a tapered stub with a thread on the end that either take a Castellated nut or on cheapo ones, a nyloc nut.
My 4wd has a tapered stub again, but the actual hub pinches around the stub...
Neil.
Neil.
no the 2wd has no castle nut, it does on the steering nuckle, but not on the TCA.
The hub pinches it exactly the same as the 4x4 with a bolts that goes through the hub.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
