Boost guage ?
Old Aug 9, 2005 | 08:13 PM
ian.gordon's Avatar
ian.gordon
Default Boost guage ?
Could someone please post a pic of the vacuum hose (on a sapphire cosworth 1992 ) that has the Tee piece put in it for the hose on the boost guage and then tell me what its suppossed to read , i.e is it meant to go above zero to pressure or below to vac ? Thanks in advance
Old Aug 9, 2005 | 08:31 PM
Neil S's Avatar
Neil S
If you look on the side of the plenum, you will see 4 take-offs. Tee into any of these (apart from the fuel pressure reg one! )
The gauge should read negative at idle, and positive on boost
Neil.
Old Aug 9, 2005 | 08:54 PM
ian.gordon's Avatar
ian.gordon
so i could cut the 1 that has the metal cone shaped bit at the end with weber written on it ? sorry for being dumb but that where i cut it but it always stays below zero all the time ?????
Old Aug 10, 2005 | 09:20 PM
Neil S's Avatar
Neil S
If you mean the fuel pressure regulator line, then I personally wouldnt have done, as thats one hose you dont want to blow off because of a cheap T piece
When you say it's negative all the time - does your car actually come on boost?
Neil.
Old Aug 10, 2005 | 10:17 PM
Daveyraveygravy's Avatar
Daveyraveygravy
Dont tap into the map sensor one either
Old Aug 11, 2005 | 07:20 AM
Neil S's Avatar
Neil S
Forgot about that one!
Here, I'll take this:
Neil.
Old Aug 11, 2005 | 07:31 AM
Kevin B's Avatar
Kevin B
T it in to the hose that runs to your dump valve. If you have removed your dv then you should have a spare 'nipple' on the inlet for it to run from anyway...
I have T'd off the dv hose but dont have any pics i'm afraid. Mine shows -10 hg at idle (but dv diaphragm is split and causing an air leak, I think it should be nearer -18hg) and obviously it shows + psi when on boost)
HTH
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
