clutch plate allignment??
whats the best way to do this?
am i better off buying a tool for the job, or can it be done by eye?
if someone could runme through it, it would be much appreciated
cheers
Dave
cheers
Dave
dave if ya woried then use ya extention bar or a bit of pipe to line it up, i bought a clutch tool but lot the fooker when i needed it
used some plumbers pipe and lined it up as i dont trust my eyes
it its too small then use tape to pack it out a bit
good luck, its easy though
I always just do it by eye.
Line up the centre of the clutch in the centre of the forks and then feel around the edge to make sure you have a consistant gap all the way round.
Also got one of those tools but usually cant be bothered to use it.
i used a extension bar from a tool kit with tape round it just till it fitted it nice and snug, not to tight tho.. the thing is you cant realy be that far out cus the bolts that hold the clutch plate on arnt that tight ,so when you lift the box up to put it on , wiggle it till you can just feel the splines, once its on it has to be in the center or it wont go .. good luck mate
andy
andy
I use a socket extension bar and tape
ya know when i done it that way i was there thinking i was the tits at my thinking out the box idea
never admited it before as i thought i would get a roasting from the passengers on the band wagon, looks like we all think out the box
I used the correct tool but I bought it years ago for my old car,I wouldn't do it without the tool because if your a tiny bit out ( say you used a extension bar with some tape on the end ) it won't go on and you will have to start again and it can be a pain
Dave.
Dave.
