help.. cooling prob? fans wont go off
put new engine in the saff filled all up with coolant but when driving the fans just wont go off. when turned off they cut off after a minute but the gauge aint reading that high.. the pipes to the rad are hot but the rad feels cold all over.. it is also new.. tried thermostat driven it for while but still stays the same.. any ideas????????????
my escos was doing this when i bought it. it was actually the temperature sender unit wich is in the side of the radiator. about Ł10/Ł12 max. think they get corroded, shit up on them. the dickhead who had the car before me couldnt understand why his battery was going dead all the time and thought it was his alarm so he paid someone to disconnect the alarm. ( so when i came to reconnect the alarm when the problem was sorted i was horrified to see the alarm all hacked to bits so i had to get a new alarm installed) i was told that this unit is the only thing that turns the fans on.hope this helps i know its not a frst but the principal could be the same
cheers sorry its a 2wd saff i had a prob with the thermostat the wrong way round so i thought so i re newed it and put the gold bit towards the head re filled with coolant and is still the same. its a standard rad with pro alloy intercooler in front.. the fans stay on when driving too and rad just luke warm but temp gauge just below the O on norm.. new pump hoses engine with new block brandnew t34.. rad also new.. i have tried all i can think of.. although it dont get so hot that it boils the headertank even left ticking over for ages... getting real pissed off with it now.
Yes, the fans should pull cold air through the radiator and into the engine bay.
It sounds most likely that your radiator has had its day and is very inneficient, yet its new, so we must look at reasons for lack of flow through its cores.... Is teh system making pressure? IE: Does the pressure cap work?
im hoping its not the rad as its a new ford one cost over 200 quid.. the cap is one thing i have not replaced thinking about it .. just had a look at it and compared to an old one and looks as if the rubber ring washer is missing. although this cap worked fine on the old engine..
Originally Posted by Stu @ M Developments
Sounds like the problem that arrises when you install an uprated alloy radiator in a cosworth. Is it a FRST though?
it was fine with the old engine in the car tho that is why im so pissed off.. it all ready had the pro alloy cooler in.. it is obviousley cooling the engine in some way as ive driven the car and it aint got that hot, ie on the gauge all new sensors too.. just the rad dont get hot like it should for the fans to cool hot water rather than luke warm.. if the rad was hot i wouldnt be bothered about the fans being on..
sounds like stat is stuck shut to me remove it and carefully drop into some boilin water you should hear it 'pop' open if not replce it
Hello !
I actually have the same problem: fans wont go off... or are very long to stop. And my rad is cold all over; but seems hot just around the fan switch (and the hoses are hot too). It sound like thermostat closes when engine's temperature become cold enough but water flow just enough to keep the temperature around the fan switch too hot to stop the fans...
You have to know that all is new in my engine bay : rad, fans, wiring, engine, thermostat, fan switch, etc... and my engine is never overheating.
Thanks for your ideas.
Best regards
Best regards
