question re: motorbike engines
how do they avoid the valves hittin the pistons, also how come then i would have to pay absolutely thousands to make my cvh rev to 8k reliably, let alone 15k+
cant be as simple as better and lighter parts, or people would be driving cars that rev to 15k...
also, they have hardley any torque aswell, whys this?
dre
dre
They have hardly any torque cause they are small engines and because they are cammed to be high revving.
The sheer weight of the crank needed in a car helps stop them revving very well.
They are just designed totally differently.
honda car engines rev to 9K+ in standard trim (S2000 for example)
So its certainly possible, but its expensive cause they engine actually needs to be built correctly, ford production budgets arent high enough for that!
Car engines need torque, torque needs strong components.
Formula 1 engines rev to nearly 20K mate, so car engines can, its just not a good idea for reliability when carrying that much weight around!
Skylines run over 10K sometimes, but can go to 15K due to the weight of the crank and rods etc that are required to handle the torque involved.
As soon as you turbo an engine, you need more heavy duty components due to the extra torque.
Some bikes physically pull the valves closed - that way they cant bounce or over-extend
The reason they rev like fook is due to low rotational mass (they're over-square, so short rods and short-throw cranks help a lot)
As chip says, power comes with revs.
Neil.
Neil.
It's down to the design and what they decided the end user needed. If they wanted to make a 9k rpm car i'm sure they could. I just dont think a relatively guttless n/a engine is likely to be developed by them for a family saloon/hatchback tho....when they dont really push performance models like honda do.
Everythings designed to a set of paramaters for a given price.....it's deciding on the paramaters that matters
F1 engines rev to 20k rpm so it's plenty possible.
As chip says weight and durability of the crank, rods, bolts, gudgeon pins etc is a major issue in getting cars to rev.
ok chip
forgot about the F1 engines etc
a bloke who works for me dad, got a zxr900r, said someting about a cam to open the valve and a cam to close it... is this bollocks?
u going to ford fair then?
Im not at ford fair im afraid, too busy this weekend, as was at TOTB last one and due to working away from home during the week, i only get weekends to play toy cars sadly.
Matt, the production standards arent a patch on honda, they arent designed to be, things like bore clearances etc, although selectively assembled no doubt, they just arent as fussy, because they dont need to be, its easier to build an engine to rev to 7K than to rev to 9K, and honda are obsessed with reliability and engine life.
Proven Legendary Status
Just to add to what Chips saying. Consider the size and stroke of a R1's pistons. (4 pistons 1 litre Compared to a CVH engine.(4 pistons over 1600) Same as a F1 engine. The pistons and stroke are very small which means higher revs are possible. (3 litres over 10 pistons)
The valves being pulled shut mentioned above is Ducatis desmosedici system. Basically all gears from crank to cams. No chain or belt and IIRC rockers instead of valve springs.
Bike engine are such great value for money!
Yamaha's 1000cc sportsbike went 20valve in the early 80's
Rode a CBR250 once, 250, 4 cyl, 16v engine
19,000rpm limit
19,000rpm limit
