what the flippin heck is going on im so mad
just fitted gaz coilovers and 18" comps to beaches cossie and the front wheels are touching the shocks the wheels are et35? any ideas anyone never had this poblem with the 4x4 only difference is that was on avos ?do you think weve been giving the wrong struts ?please help im snap
matt had a problem with his
the struts cant be wrong... there are only 2 types for the sierra, and the only difference is the bush size onthe bottom where it bolt onto the hub.
you're going to need different ofset wheels or some spacers i'm afraid.
or run the car at a height where the spring platform is higher than the wheel...
i run esccos rims on a 2wd and have zero problems
how can it be a gaz issue the shox fit PERFECTLY on the car, it's the WHEELS that dont fit
it's an ofset/space issue end of...
i forgot the other option... run smaller springs... (or does it hit the spring platform?)
the rim is catching the platform
jim are you fucking real its a shit design as THE OTHER COSWORTH IN MY BACK YARD HAS THE SAME WHEELS BUT USING AVO COILOVERS AND NO PROBLEM
What length springs are you using on the front? A shorter spring will raise the platform and get it away from the rim!
the rim is catching the platform fookinhell what the fook ofset have you got what are they, 10j or something sure you havent got any knackered bushes?
and you must be running the platforms VERY low for them to be near the rim anyway... you want them to be more in the middle of the tyre or it'll look like a "saxo slammed on 20s"
not sure on the lenth spadge mate its the ones that come in the kit
Get a pair of shorter springs like i had to do once and this will sort it!
Mike R sells the springs
ps my spring platforms actually sit HIGHER than the tyres
but i run a sensible ride height on sensible springs
were gonna try spacers first if not shorter springs might have to be the option
whats the difference between the 4x4 strutts and 2wd im just wondering if theyve given us the wrong 1s
i already told u :P
the bush at the bottom where it bolts to the hub is a different size :P
that's IT...
it's the different suspension arangement (hubs, TCAs etc, causing different offset) that spadge is talking about... not the shock absorbers themselves.
cossiecrew, this is how low my car is:
hardly a monster truck (ps bad picture, car looks shit )
that's IT...
It's not hard is it!
I'll even supply a link for you to browse at leisure and decide which springs you want.
http://www.rallydesign.co.uk/catalog...1152_1153_1154
Originally Posted by martin-reyland
Originally Posted by DazC
Use a shorter spring....
Not all cars use the same length spring. It's not a design fault because for all they know you might be fitting them on a track car or rally with an ET15 offset or something stupid. It also depends on the ride height required.
Thanks all, ive been to unhappy to even want to post on this topic!!
Springs will be here tomorow to hopefully sort my problem, cheers mike!!
Just hope it sorts it as ive had lots of bad luck this week
Cars gona look mint
Cars gona look mint
Originally Posted by 3dr-rally-slag
i had the same problem with the gaz shocks on my car, if i ran 2wd offset i had to use huge spacers to clear the shocks- ended up changing the wheels
rainbird the springs turned up this morning just fitted them and they miss the wheel now just awaiting the rear wheel coming back before test run but cheers for top service you saved beaches ass
