t4 hose?????????
t4 hose?????????
want 2 fit t4 on car but dont want 2 change intercooler,
does anyone make boost hose from t4 turbo 2 t3 inlet
size ic, dont really want hassle ov getting bigger port
welded on ic
welded on ic
ROOSEMOTORSPORT@aol.com
He'll make you one pretty much anysize.
However it will be restricting airflow having such as large reducer coming from the T4 and I don't think you'll be able to run as much boost (as if you use a T4 sized hoses) without running into trouble.
just remembered he only does the airfilter hose in reducer sizes
or how about some bling stainless pipes with samco type ends
Lee @ fusion should be able to knock them up, then all you need it a little bit of T4 and T3 hose
Re: t4 hose?????????
welded on ic
welded on ic
rod wrote
got a point m8
ryan wrote
yea m8 but every time i go in garage it does me in just sat there waiting 2 go on
Why not do the job properly, dont bodge it.
ryan wrote
you've not had the new t34 long
Russ Payne
25-09-2015 08:29 PM
