THIS sucs.... :(
DANISH cosworth abuser
THIS sucs.... :(
At last i got the car running after i blew the engine in september last year, was out and trying to map the car on the road, everything is fine until i try to launch the car for the first time with the new clutch and all...
Was running a little over 14psi at that time, bout hell it went
Stopped at a sign, switch on the launch-control/anti-lag, 7000rpm and released the clutch...... *BAANG*
All the lights led up in the dashboard and i quickly turned off the engine
pushed the car in to the side, there was oil everywhere on the road, and the car dident move for more then 10fet, looked under the car and the front diff had litterely exploded and has taken the sump with it....
Now it`s time to go home and take the engine apart again
std diffs, the front one was new, 10k km, but i had welded on reinforcements on the casing and on the sump + i put the 5mm steelplate between the lid and the casing...
yes just like that, but mine took the sump apart also, there is a hole and a long crack across the sump in the bottom, it has also destroyed the link between the gearbox and frontdiff....
sheeeeet mate
sorry to hear..
hope you get it sorted soon!
if you switched the engine off that quick then you might of got away with it ?
hope it all goes back together ok!
sorry to hear..
got the diff gearbox and the sump of now, engine seems ok, bearings are ok
no scratches in the cylinder from underneeth that is...
The sump was cracked all the way over
Now i am just missing a new sump and diff
i know that mate, but dident exatly count on the siff would blow up at 15psi, would have expected it at 25psi or more...
Only thing is that i don`t have a grand now for the thick wall casing diff
