difference in cossie blocks re: NOISE
Football Cwazy
since i'm new to the whole cossie thing thought i'd better ask the first of many questions
my engine has a very slight noise on idle ( haven't really noticed it when driving ) guess only way to describe it is a knocking. it's a 2wd saff by the way.
my question is,is this noise normal for the 205 block? i am led to believe it is due to the design of the gudgeon pin?? and the 200 block shouldn't have this problem due to differences in design.
am i talking bollox
can't find any info
am i talking bollox
can't find any info
The 205 suffers from piston slap when cold, once the piston expands a bit it should dissapear.
It will idle perfectly when when warm though.
The 4x4 200 blocks had an off-set gideon pin to rectify this by pushing the piston up one side of the bore thus elimitating the piston slap.
*This is out of Andys memory which is a mess most of the time so may not be 100% true
Football Cwazy
it has had a rebuild,but i haven't got receipts to show it as far as i know.mileage is about 88k.
Andy Fisher ( cosworth expert at brooklyn ) has had a good look over it and said it's normal but would like to know if anyone else has this noise and all is well.
sure its not top end? tappets.
unless its been rebuilt with wronge size bore, it shouldnt have piston slap once been runnin for a couple of minutes.
just finding my feet
little ends , remember when i took my engine apart to remove my little end rattle, just cause i was bored and thought "why not"
turns out the piston on number 3 was offset, the rod was making it off set and making my little end rattle, the little ends are fine though
shame the rods,pistons and block are fooked
mate if its a small noise then dont worry about it, if it does keep anoying ya turn up the stereo, all cossies do is give ya heart problems, just drive it and dont touch it until a piston has popped out to ask for some time off, or ya will end up with a cossie ornament just like i have
serious though, unless the cars not running right and the oil presure is fine then drive the car and enjoy it
Football Cwazy
it's no worse than any other cossie i've heard to be honest.maybe one of you experts can have a listen at ford fair for me
cheers people
cheers people
