What is this light on me ecos dash??
Is this light working on your cars? The lamp itself is OK on mine but can't get it to work. I bought a new sensor but still there is something wrong. Anybody with experience with that?
Originally Posted by turbo-5
filled to the brim mate and still on lmao so where is the swicth then bet its a right pain to get to
u will know when its low cus you cant get the buggs off ya windscreen!
Check the wiring where it goes through inner wing the insulation chaffs and sender goes tits up or get another sender and change it over when you do your map brkt its alot easier with wheel off and arch liner out the way m8.
it's the washers
a cable has come off mine and new switch going in tonight,
when i start my car it flashes for 10 seconds to say sensor faulty,
but if it is perminaltly on it's low on water
Originally Posted by Cola
Dumb fooking question but do the washers actually work? The light's on on mine but then mine don't work.. and yes, they do have water
I had this when big multiplug for washers lost contact. Try spraing some electric conetors cleaner there and pluging it back more securely.
If I remember it right you must get to big multiplug on the engine bay's side of washer tank. It's somwhere there availible from below the car. But I don't remeber it exactly. Can check in workshop manual if you want?
Many thx also for all your replys
If you need anymore help - just PM/e-mail or anything. I'mm be taking out fluid level sensor tommorow so I will be looking at manuals anyway.
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
