Best cossie alloy rad??.........
My AH one is good! temps often at 79C on a cruise about and fans hardly cut in! Even when we had the boiling hot weather, i was giving it some through the country roads and was avg abour 90C
Originally Posted by Benn 304R
they normally do deals for show, ie no vat added
Porkie, extra turbo cooler... Dont start, this last month has cost me an absolute mint.. just a rad will be fine for now
Mike how many std Rads you had on your car? Or should I say why do you suggest std over alloy?
as porkie says the turbo cooler makes alot of difference mine was always in the 80's cruising but now there in the 70's and the quality is spot on
Originally Posted by Porkie
Damo, its not alot more and WELL worth it
Cant wait it looks sweet, thanks for the picture
all you guys who run lower than 85 degrees do you run thermostats ?
i have a pro alloy rad and a 88 degree thermostat.
my car stays about that temp all the time doesnt really go up doesnt go down just about 90 degrees all the time.
Originally Posted by NORTH YORKS RS SPARES
I have the same setup as in the piccy , all PRO-ALLOY and it looks / fits and works perfect ,,worth every penny ,
Damo... you know it makes sense
Originally Posted by Lambchop
STANDARD .
this actually relates to the cossie i'm gonna buy...is a standard one up to the job?
chop
anything that anyone else has that mike doesnt... is in his eyes unneccesary!
the fact we all run quality alloy rads and Mike still retains the plastic capped std one... must mean that we are all wrong
i just got a pace 60mm one for my car and so far it looks the bussiness but its not been fitted yet
i wanted a proalloy one to match my cooler but after phoning around to get prices i was warned off them by two diff "shops" from the mags.
said they dont fit right and kink hoses or something??
wasnt taking any chances so just got the pace.
was three hundered and thirty pounds sterling i believe...
590 BHP/Ton
however the design has changed since then
590 BHP/Ton
