puegeot offsets ??????
25-07-2005, 07:28 PM
what ET offsets are pugs ??
ie 205 etc ?
cheers..................matt
25-07-2005, 07:35 PM
I believe there ET 16 mate
25-07-2005, 07:38 PM
Im sure there ET 16
this site lists them as 15-25
but im sure all wheels that come on a 106/306/205 are ET 16
25-07-2005, 07:41 PM
25-07-2005, 07:43 PM
25-07-2005, 07:47 PM
25-07-2005, 07:48 PM
as a rough guide the older ones are ET15mm
206's and 307's take 25mm offset. dont know about the 407 tho
25-07-2005, 07:49 PM
O by the way, ford wheels fit onto Peugeots with 10mm spacers
so Peugeot wheels wont go onto Fords if thats what ur wondering
25-07-2005, 07:50 PM
what would happen if you put an et15 to 20 offset wheel on a et35 offset car ?
and i think all the 407's are all 5 studs
25-07-2005, 07:51 PM
Quote:
They'd stick out a extra 15-20mm
25-07-2005, 07:53 PM
25-07-2005, 07:55 PM
u can get them machined down and they would fit.......dependant on the offset it would be between 10 and 20mm
25-07-2005, 07:57 PM
What Peugeot wheels u after ???
25-07-2005, 07:58 PM
well whats wrong with the wheel sticking out that little bit further ??
would it feck the handling up etc ??
25-07-2005, 07:59 PM
all i know is they are pug offset 4 studs
sorry guys im doing my hardest to understand this lol
matt
25-07-2005, 08:05 PM
pug stud pattern=4x108 offset 15mm
ford stud pattern=4x108 offset 35mm
this means that on the pug wheel there is a big amount of metal on the back of the wheel (where the bolts go thru), as compared to less on the ford one.
if u get the wheels machined by 20mm (where the wheel touches the car's wheel hub) then they will fit properly.
If not, they will still physically fit but will stick out from under the arches and u could get stopped off plod, cos its illegal to have sticky oot wheels
26-07-2005, 07:18 AM
I got my eyes on a nice set of Racelines mate that would look lovely over your new brakes
26-07-2005, 07:50 AM
26-07-2005, 08:01 AM
Pug centre bore is 65.1mm
Ford centre bore is 63.3 mm
So if you put pug wheels on it will rely on the bolts to centre the wheel and not the hub spigot.
26-07-2005, 08:09 AM
....but you can buy the plastic hub spigots that will make em fit spot on!!!
26-07-2005, 08:16 AM
26-07-2005, 08:44 AM
26-07-2005, 08:56 AM
IainRS1700T
25-09-2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
turbotrev
14
06-09-2015 10:27 AM
track.focus'd
12-08-2015 05:53 PM
