Turbo's with cut back blades ?????
Old 25-07-2005, 01:46 PM
AlexD
Post Miester !
AlexD's Avatar
Default Turbo's with cut back blades ?????
Quick question.....
How do you identify if a turbo has cut back blades ?? and
what are there main purpose...
I should know this by now
Al.........
Old 25-07-2005, 01:47 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Dont know how to see if its got it , but i think there done for a quicker spool-up
Old 25-07-2005, 01:48 PM
DaveEscos
DaveEscos's Avatar
exhaust wheel
clearly visable to see if they have been ground back
Old 25-07-2005, 01:55 PM
AlexD
Post Miester !
AlexD's Avatar
just one set of the blades or both ?? does it look like a small cut outta the edge of
the blades ?
Al...
Old 25-07-2005, 01:57 PM
Tony Turbo
www.ctuceilings.co.uk
Tony Turbo's Avatar
Main purpose is.....
Old 25-07-2005, 01:59 PM
AlexD
Post Miester !
AlexD's Avatar
lol... Such a comedian !!
Al....
Old 25-07-2005, 02:00 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
cut back blades are to reduce turbine speed at high boost levels to prevent overspeed,the reduction in surface area of the exhaust blades actually increases lag
Old 25-07-2005, 02:01 PM
Charlie Chalk
Unknown.
FPMSL
Old 25-07-2005, 02:03 PM
Adam_BlackRS
Ex Ford Man
Adam_BlackRS's Avatar
Are these ?
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
So when are you going to disclose who told you this ?
Old 25-07-2005, 02:04 PM
AlexD
Post Miester !
AlexD's Avatar
Erm... Thats the compressor wheel m8...........
Al........
Yep, spot on, it means that effectively there is more room for the gas to escape past the blades without acting on them, so it gets LESS efficient basically.
Old 25-07-2005, 02:05 PM
Mike Rainbird
Caraholic
As has been said, it is in the EXHAUST wheel NOT the compressor .
Old 25-07-2005, 02:06 PM
AlexD
Post Miester !
AlexD's Avatar
Whats the point then ???
Al..
Old 25-07-2005, 02:07 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Originally Posted by Adam_BlackRS
Are these ?
they just look damaged
Old 25-07-2005, 02:10 PM
Charlie Chalk
Unknown.
Are these ?
Never knew you could mount a sub in the engine bay
Al..
To allow the turbo to flow more air without generating too much boost, its kind of a halfway house to moving up to a larger housing.
bodge really IMHO
Old 25-07-2005, 02:11 PM
keithG666
keithG666's Avatar
so you can't see wether the turbo has cut back blades???
Old 25-07-2005, 02:12 PM
AlexD
Post Miester !
AlexD's Avatar
Cheers that all answers my questions
Anybody got any pics tho ????
Al...
Old 25-07-2005, 02:14 PM
DaveEscos
DaveEscos's Avatar
the clues in the picture!!!!!!
Old 25-07-2005, 02:15 PM
Mike Rainbird
Caraholic
The point is when pushing a turbo to it's absolute limit (as is regularly done within the Cossie tuning scene), it is designed to protect the turbo from over-speeding and destroying itself.
Old 25-07-2005, 02:19 PM
External wastegate is a far better way of doing that on any given turbo IMHO
Old 25-07-2005, 02:20 PM
Mike Rainbird
Caraholic
Keith,
Not by looking at the compressor .
Tony,
Bigger clue please .
Old 25-07-2005, 02:23 PM
Keith,
Oh the pain
Old 25-07-2005, 02:24 PM
Turbosystems
Super Moderator
Chip what u on about ?????
it is the exhaust wheel blades that have a reduction of surface area and it is for high boost applications only, to prevent turbine overspeed at these high boost levels. The higer the boost the higher the turbine speed.It is important that the turbine does not go beyond it's designed operating speeds.
If you look at the exhaust wheel you can see the blades have obviously been ground back commen cut back is 7 degrees.
Old 25-07-2005, 02:27 PM
What am i on about where?
The idea is to stop the turbo spinning too fast, an external gate can do the same thing by bleeding air off to prevent it going over the turbine, thats what i meant.
Old 25-07-2005, 02:30 PM
Turbosystems
Super Moderator
doesn't read like that chip
and it's exhaust gas the air comes out the other end i believe
Old 25-07-2005, 02:31 PM
Mike Rainbird
Caraholic
So can an integral wastegate . This is NOT what cutting back the blades is for, it is done JUST for the reason Tony stated...
Opening the wastegate reduces the flow as you state, but this also has the effect of reducing the boost. Cutting back the blades achieves something similar witout reducing flow over that exhaust wheel. This retains the boost pressure, but reduces back pressure and stops the turbo from overspeeding.
Old 25-07-2005, 02:32 PM
LOL, fair point on me referring to exhaust gas as air when technically it isnt, although ironically it is the moment it leaves the exhaust of course as air doesnt actually have a defined composition its just whatever is present!
I'll try and word things more carefully next time though if that was confusing, but yes i was talking about the hot side the whole time.
Turbosystems
Super Moderator
Al..
bodge really IMHO
this bit needs explaining
Old 25-07-2005, 02:33 PM
Thats not always true as the internal gates are often very small, take the KKK K16 fitted to a calibra turbo and pump a load of nitrous in too and see how well the internal gate manages to cope with it for example!
Old 25-07-2005, 02:37 PM
Turbosystems
Super Moderator
they aren't small on the turbo's that this topic relates if anything the wastegate penny is to big.The integral wastegate was a revolution.It is old turbo's that ran seperate wastgates
Al..
bodge really IMHO
Like in the example i gave above where if you use nitrous you end up with a massive volume of exhaust gas to try and flow and the internal gate wont bleed it off fast enough, some people try and stop the turbo exceeding max boost pressure in this circumstance by using cut back blades which effectively allows some of the exhaust gas to squeeze past the blades without turning them, but in my view thats not as good an option as a decent wastegate with the relevant control because it means that the "leak" is there all the time, ie some of the air goes past the blades when you are trying to build boost too (hence more lag) as well as at the times you want it to (to avoid overspooling)
Old 25-07-2005, 02:39 PM
How do you know what turbo this topic relates to?
(the picture posted wasnt by the topic starter)
I thought it was just a general interest type of question?
Turbosystems
Super Moderator
obvious reply to you chip is don't buy a vauxhall lol
This is a ford site and the waste gate penny on a vauxhall wasn't really relavent to it's operation as they always fell off and became bonnet ornaments for the car behind lol
Old 25-07-2005, 02:41 PM
Absolutely in tears
SO true!
Turbosystems
Super Moderator
chip on a big ford site like this the topic is normally ford unless i am a complete numpty the vauxhall sites talk about vauxhalls
and it is a saph cossie in his siggy
Old 25-07-2005, 02:45 PM
Nah, people ask questions about all sorts of different makes on here mate.
Not to mention:
"why are women so fooking complicated"
"fooking taxman, how do i avoid?"
"is this wart on my knob something to worry about"
Thats what makes it so interesting, the general chat section can literally be about anything!
Stealth Bomber
Stealth Bomber's Avatar
That's one fucking moody looking Saff!
Old 25-07-2005, 02:49 PM
Turbosystems
Super Moderator
Not to mention:
Out of your 3 options i would be far more concerned about the wart personaly
Quick Reply: Turbo's with cut back blades ?????
