Urgent help needed,how long before oil pump picks up??
How long should it take before i get oil coming through the
oil feed line to the turbo?
The pump HASNT been primed,ive filled the engine with the right
amount of oil and i also removed the plugs to try and help the turnover speed but i still cant get any oil pick up and the engine also killed a
fully charged battery
Is there anything else i can do to help the oil pump pick up?
When we were preparing to start Nightdavvas car the other week we tried turning the car over & over for about 10minutes on & off without any sign of any oil from the oil return pipe of the turbo.
Then we attached a drill to the oil feed drive & within a minute or so we had oil!!!
I know yours aint a cossie lump but could you do something similar perhaps???
HTH!!
HTH!!
big_Rad
15-09-2017 09:36 AM
