help with a problem
Old Jul 24, 2005 | 01:46 PM
RSCossieGaz's Avatar
RSCossieGaz
Default help with a problem
a mates FRST is absolutley pleuming what seems like white smoke from the exhaust on tick over which has only just started happening.Not too long ago the car did over heat etc
is this a sign of the h/gasket gone tits up? as we looked at the dip stick and oil cap and couldnt see any signs of water droplets/mayonase type symtoms
he hasnt been using the car of late but when he was did had to fill the header tank reguraly coz was loosing water this was after it had over heated
is this h/gasket probs??
Old Jul 24, 2005 | 01:48 PM
escortrsmatt's Avatar
escortrsmatt
yep def sounds like head gasket.white def = water!!
Old Jul 24, 2005 | 01:51 PM
Dragon's Avatar
Dragon
Sounds quite likely to me
Old Jul 24, 2005 | 01:53 PM
Ginge !'s Avatar
Ginge !
just finding my feet
are ya local to a mot bay by any chance, if so get them to wave the lambda wand over the car and see what it picks up
it might me the water is leaking into the bore and the oil ways aint got yet
Old Jul 24, 2005 | 02:15 PM
gibbo frst's Avatar
gibbo frst
i just had this on the missus frst took the head off thinking it was gonna be the gasket but found it to be 2 cracks between the valves on the middle 2 cylinders. but the smoke on this one only happened once the car had warmed.. not cold.. but also had similar problem with an inlet manifold gasket leaking through the waterway into the ports... the garage tested this on the meter said H G gone but i just changed inlet gasket and all was fine..
Old Jul 24, 2005 | 02:17 PM
Ginge !'s Avatar
Ginge !
what meter, ya mean the CO jobby, that just confirms there more than just water in the water
Old Jul 24, 2005 | 02:20 PM
gibbo frst's Avatar
gibbo frst
he said it meant that water was being burned but was through the head gasket leak but was found to be leaking through the two inlet ports either side of the waterway on the inlet manifold
Old Jul 24, 2005 | 02:24 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Its also possible its the turbo instead mate - especially as there are no other signs of the headgasket having gone!!
Old Jul 24, 2005 | 02:27 PM
RSCossieGaz
cheers ppl sort of was guessing it was h/gasket but if it was turbo that was shafted wouldnt it be blue smoke as a sign i e burning oil etc
Old Jul 24, 2005 | 02:33 PM
Lee_R21Turbo
Not necessarily mate - remember water passes through the turbo too!!! I have seen on a couple of turbo'd cars the same symptoms & it turned out to be the turbo!!
Worth trying before whipping it all apart tho if you've got a spare one between you!!
Old Jul 24, 2005 | 02:38 PM
gibbo frst's Avatar
gibbo frst
yeah suppose so but this was the prob on mine.. and mine didnt have the water feed to the turbo at the time.... good luck anyway.
Old Jul 24, 2005 | 02:40 PM
Lee_R21Turbo
Well yeah - if it dont have the water feed connected then it aint gonna be that! LOL! Disconnect the water to it just to test it!!!
Old Jul 24, 2005 | 02:41 PM
RSCossieGaz
forgot to mention the fezzy has a T3 turbo conversion and the turbo is a s1 item so is oil cooled
Old Jul 24, 2005 | 03:17 PM
Lee_R21Turbo
Ignore me then!!!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
