pectel ecu
there is no T6
theres a T6 2000
and a T6M 2000
T6M
T6M 2000 Motorsport ECU Specification:
Processor Motorola 32 bit 21MHz
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Voltage Range 6 to 18 volts
Temperature Range -40°C to 85°C
Injector Drives 12 Low/High Impedance
Ignition Drives 4 Internal Clamp
PWM / Relay Outputs 9
Crank Sensor Type Hall Effect / Inductive
Cam Sensor Type Hall Effect / Inductive
Analogue Inputs 11
1 K-type thermocouple
2 UEGO Lambda
Internal Sensors ECU Temperature
Battery Voltage
Communication RS232
Can 2.0B
Dimensions Length 167mm
Width 145mm
Height 40mm
Weight 680g
Case CNC Machined HE30
Connector AS Connectors
Datalogging 40 Channels
Data Throughput 1000 Samples/Second
Engine Configuration 1 to 12 Cylinders
2 or 4 Stroke
Natural/Forced Induction
16000rpm maximum
Application Software DescproW and Pi Toolbox
T6
T6 2000 Motorsport ECU Specification:
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
PWM / Relay Outputs 8
Analogue Inputs 8
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
Connector 55 way AMP
2 or 4 Stroke
16000rpm maximum
theres a T6 2000
and a T6M 2000
T6M
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Analogue Inputs 11
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
2 or 4 Stroke
16000rpm maximum
T6
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Analogue Inputs 8
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
2 or 4 Stroke
16000rpm maximum
there is no T6
theres a T6 2000
and a T6M 2000
T6M
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Analogue Inputs 11
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
2 or 4 Stroke
16000rpm maximum
T6
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Analogue Inputs 8
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
2 or 4 Stroke
16000rpm maximum
theres a T6 2000
and a T6M 2000
T6M
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Analogue Inputs 11
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
2 or 4 Stroke
16000rpm maximum
T6
RAM 512KB - 2MB
Flash 256KB
A/D Accuracy 10 bit
Analogue Inputs 8
2 UEGO Lambda
Battery Voltage
Communication RS232
Can 2.0B
Width 145mm
Height 40mm
Weight 680g
2 or 4 Stroke
16000rpm maximum
have ya ever thought about getting a pectel ecu dave
Andreas is correct.
T6 is an old ECU, still very capable but any new codes and updates are written for T6 2000 which replaced the T6.
T6M I believe can run active transmission IIRC.
If People hadn't have ripped into the new user "Pectel", he may have stuck around longer and you could have asked him what the differences are....
T6M has more inputs and outputs comms ports and datalogging memory but can't do active transmissions..
T6M inputs...
13 Analogue
2 lambda
2 thermocouple
9 digital
T6M outputs...
9 PWM expandable
T6M communications...
2x CAN
1x RS232
T6M datalogging memory
2mb
Sampling on 40 channels at 1000hz
T6 inputs...
8 analogue
2 lambda
1 thermocouple
6 digital
T6 outputs...
6 PWM expandable
T6 communications...
1x CAN
1x RS232
T6 datalogging memory...
512kb expandable to 2MB.
T6M inputs...
13 Analogue
2 lambda
2 thermocouple
9 digital
T6M outputs...
9 PWM expandable
2x CAN
1x RS232
2mb
T6 inputs...
8 analogue
2 lambda
1 thermocouple
6 digital
T6 outputs...
6 PWM expandable
1x CAN
1x RS232
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
