Brake Problems - STILL!!!
Old Jul 22, 2005 | 03:58 PM
John Laverick's Avatar
John Laverick
Default Brake Problems - STILL!!!
Had the discs skimmed on my Motor which got rid of the brake vibration under light braking....did the Croft Trck Day and all was fine.....two weeks later and its starting again
Took the hubs to an engineer and he suggested the bearing mounting surface was out by 5thou from specification and this may mean the hub/wheel/disc is moving within the bering...causing the disc to touch the pads...heat up and warp!!
Is this feasible??
I recently replaced the front wheel bearings on both sides and I didn't press them into place...the hub just slid into the bearing and I torqued the nut.
Should the bearings be press fitted?
Old Jul 22, 2005 | 09:22 PM
James's Avatar
James
What discs are they?
If it was ok when you had the discs done and you've since done a track day and they're fooked again i'd say it was deffo a disk problem.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
