quick timing question (4x4)
Old Jul 18, 2005 | 06:21 PM
escortrsmatt's Avatar
escortrsmatt
Default quick timing question (4x4)
when timing up the 4x4 cossie engine, what do you line up on the crank pulley?do you put the bit that sticks out in line with the mark on the block or the little cut out?cheers in advance! just seen the cam timing is def out on my car and want to make it right to see if iv destroyed anything!
Old Jul 18, 2005 | 06:24 PM
Graceland's Avatar
Graceland
Team HOTHOT!
you line the mark on the block with the TRAILING EDGE of the TDC mark on the crank pully.
the dizzy pully timing mark will be pointing to the half moon at 1 oclock
and the cam pully timing marks will be pointing to each other in line with the line where the camcover mates to the head
Old Jul 18, 2005 | 06:25 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
check its correct,then double check|!!!!!!!!!!!!!!!!!
Old Jul 18, 2005 | 06:26 PM
escortrsmatt
cheers guys!nice one.
Old Jul 18, 2005 | 06:27 PM
Graceland's Avatar
Graceland
Team HOTHOT!
there ya go
bigryrs
Mar 28, 2016 09:11 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Caddyshack
Aug 19, 2015 07:29 PM
cossie4x4
Aug 14, 2015 06:29 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
