Pop went the cossie, and the cossie went pop!!
Old 17-07-2005 | 10:45 PM
escortrsmatt's Avatar
escortrsmatt
Default Pop went the cossie, and the cossie went pop!!
just got recovered home. slowing from speed and engine died.no bang or smoke or anything else just died.when you try to start it, it sounds like there is no compression.cambelt is fine, didn't overheat, was running fine!!think the only possibility is the belt has jumped a few teeth. fingers crossed its not gonna be super expensive!any other ideas what it could be? sympathy please!!
Old 17-07-2005 | 10:57 PM
andyescos's Avatar
andyescos
TDC Sensor I think, does it turn over really fast? see if the fuel pump primes when you turn the key? My old 3 door did exactly the same on the first day I got it, not happy, but easy to fix.
Good luck.
Old 17-07-2005 | 10:59 PM
escortrsmatt
the fuel pump does prime yeah.and it does turn over quite fast aswell.hope it is this!!
Old 17-07-2005 | 11:03 PM
ryan_belfast's Avatar
ryan_belfast
Sounds like a cheap fix....
My cosworth went boom at 150mph a month ago and its still off the road, its not a nice feeling so i have some sympathy for you... Altho mine at the minute has stung me around £1500 and its still not back together
Old 17-07-2005 | 11:05 PM
escortrsmatt
fingers crossed for a cheap fix.its a run of bad luck for me and a couple mates - one has torn a hole in the floorpan of his bmw and another has blown the gearbox on his focus!gutted for you though ryan.
Old 17-07-2005 | 11:08 PM
ryan_belfast
My front prop came off at 150, smashed off the ground, blew the gearbox and the front diff also went under the stress of it all, clutch also jammed in. So count yourself lucky boyo!!!
Its all the fun of owning an RS though, going on a long trip and not knowing if your gonna come home driving or on the back of a trailer
Old 17-07-2005 | 11:11 PM
escortrsmatt
ouch!i felt that one in my wallet aswell - let alone my own problems!
Old 17-07-2005 | 11:12 PM
big_wig_074's Avatar
big_wig_074
when this happened on mine it was the bottom pulley,it stripped the teeth off the cambelt causing the top end to stop while the bottom end carried on at 70mph!!!!! that was the last time i EVER drove A2 WWE
Old 17-07-2005 | 11:14 PM
escortrsmatt
this is the first time iv had to be recovered home been driving almost 3 years and this is my 5th ford!trust the most expensive to be the one that breaks!
Old 17-07-2005 | 11:17 PM
ryan_belfast
How much did yours cost? for me to get trailered 30 miles it cost me £140! robbing bastards.
Old 17-07-2005 | 11:19 PM
escortrsmatt
blimey!! was prob only about 6 miles but cost me 40 quid.so not horrific
Old 17-07-2005 | 11:31 PM
rabmc's Avatar
rabmc
I know you have probably checked this but fuel cut off switch or cable leading to it my spare wheel somehow pulled my wire out on cornering resulting on it dying and not firing up just a thought mate
Old 18-07-2005 | 02:07 AM
SPo0n's Avatar
SPo0n
these cosworth mobiles sound very reliable
Old 18-07-2005 | 08:54 AM
escortrsmatt
fuel pump runs fine.i think that the cambelt has jumped a few teeth on the exhaust camshaft!which would mean the exhaust valves would be open on the compression stroke - therefore no compression!
Old 18-07-2005 | 09:06 AM
S3an's Avatar
S3an
could it be the rotor arm has gone, just a thought if it suddenly died with no apparent reason, seen threads like this before on here
Old 18-07-2005 | 09:41 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
he has all ready said it has no compression,how could it possibly be the rotor arm,tdc sensor,or fuel pump cut out?
are you lot just winding him up or are you really that in the dark about how a yb works?
my money is melted piston/pistons.running lean at the end of a high speed run is the norm,especially if the pump is old or standard.
Old 18-07-2005 | 10:10 AM
S3an's Avatar
S3an
he asked for thoughts and that was nine, for fooks sake. excuse me but where did it say he has lost compression. he merely said that it sounded like he had lost compression ( whatever that sounds like )
Old 18-07-2005 | 10:18 AM
Micky The Finn
Former Sponsor
sorry sean,by your last comment i dont think we need to argue over this,if you dont know what a car sounds like without compression i now understand your diagnostic post.
Old 18-07-2005 | 10:22 AM
rabmc's Avatar
rabmc
Would this not result on smoke ? number 4 went on my old car resulting in this ? or is this not always the case did not say if he was giving it some or not or again is this not always the case with melted pistons
Old 18-07-2005 | 10:26 AM
Micky The Finn
Former Sponsor
not necassarily much smoke if it has only melted down the side of the pistons,if its put a big hole in then yes,even less lightly to smoke if fitted with a good breather system.hard to say without actually haveing the car in front of us but knowing cosworths it wont be anything simple.
Old 18-07-2005 | 10:28 AM
Micky The Finn
Former Sponsor
lots of engine parts in stock here by the way.
5 200 blocks
5 cranks
various heads and loads of rods and pistons.
couldnt resist that could i.
Old 18-07-2005 | 10:36 AM
ryan_belfast
Here TF Rallyesport i may be calling you in a few days as i might need some engine parts, gotta get my car back together then see if the engine fires up.
Old 18-07-2005 | 01:36 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Same here, three theeth stripped off the belt by the bottom pulley, luckily (?, I was coasting to a stop, so "only" 16 valves, no piston damage
Old 18-07-2005 | 04:56 PM
whitneyd's Avatar
whitneyd
Is your rotor turning while the engine is cranking? This will tell you if your timing belt is fooked.
Old 18-07-2005 | 07:25 PM
escortrsmatt
the cam timing is definitely out by at least a few teeth just trying to set it on tdc to fing out which one is (or both!!)
Old 18-07-2005 | 10:17 PM
escortrsmatt
update!!have corrected the timing and there does appear to be plently of compression when turning the engine over by hand and there is no contact between valves and pistons.have tested for a spark at the plugs and that is fine.i think the injectors a clicking(indicating they are working aswell)im starting to run out of ideas now!! anyone got any??
Old 18-07-2005 | 10:31 PM
big_wig_074
take the head off,dont guess!!!!
Old 18-07-2005 | 10:44 PM
escortrsmatt
may get a compression tester before i do that.anybody know what kinda figures i should be getting from a compression test?would a faulty crank sensor cause the injectors not to fire?
Old 18-07-2005 | 10:57 PM
big_wig_074
according to my book it should be 8.5 bar (123 psi)
Old 18-07-2005 | 10:58 PM
pee vee's Avatar
pee vee
if you got more than 120 psi then its cool i think..
the crank sensor runs the igniton sequence?
the Phase sensor doe the fuel?
(thats how i thought it was anyway)
so you corrected the timing and its still not running?
Old 18-07-2005 | 11:05 PM
escortrsmatt
i deffo have the cams and crank timed up correctly!think i have the dizzy timed up right but am going to double check it tomorrow after checking a picture that was posted up earlier.
Old 18-07-2005 | 11:10 PM
pee vee's Avatar
pee vee
the dizzy could be quite easy to get a tooth out
(but it should still sorta run even if it is)
the mark to line it up on kinda hides under the plastic phase sensor cover!
you aint run outta fuel have you mate lol
TBH if the timing was that far out, then its quite possible that there is valve damage
Old 19-07-2005 | 08:17 PM
escortrsmatt
have had another good look tonight and when the cambelt is off there is movement on the exhaust cam pulley.this would indiate that the cam comes away from the hvas.which leads me to believe that the valves are slightly bent.ie not allowing the springs to fully expand and therefore the hvas sit lower.does that sound about right?
gcfcos
59
06-10-2015 06:04 PM
XR4
Ford XR Range
01-10-2015 01:46 PM
A.t.p
29-09-2015 06:04 PM
cossie330
27-09-2015 05:13 PM
Russ Payne
25-09-2015 09:29 PM
Quick Reply: Pop went the cossie, and the cossie went pop!!
