Single port barrel throttle body/plenum
Is there such an item?
I know the obvious one like the Mountune 4 Port barrel plenum
![](http://www.mountune.com/acatalog/C873.jpg)
But is there any type of throttle body that has no butterfly that can be used with a single port manifold/plenum??
How about a Zetec head with barrel plenum?
Any info would be great
i wouldnt bother wasteing you money on a roller barrel throttle,,,, ive read a few reports and thet all say that the throttle plate becomes invisible at high flow rates (aslong as the body is big enough)
IMO A butterfly that is in the middle of a Throttle body will cause restrictions and disturb the air flow charateristics. Regardless of the size of the throttle body.
Even @ full throttle there is not a 100% open port with butterfly.
With roller barrel you will have 100% air flow, if it is a decent design manifold the air flow will be alot more effective. Obviously raising the amount of air a manifold/throttle body can supply.
GARETH T,
What reports have you been reading? Any links?
GARETH T,
you could profile the butterfly to a point at either end to reduce the restriction,i know someone who did this,but he was hell bent on just doing things because he could,but the theory is sound!
Originally Posted by sibster
That's the inlet manifold off e-bay...
I have worked on the type of maifold on ebay before, if it is the same as the one i have seen, it is not a roller barrel type and has four butterfly's controled by one shaft.
Regards
Jano,
I thought the Focus WRC still retained the butterfly....
I seem to remember seeing an auto cross or grasstrack car never took a lot of notice but it had a XE engine and some form of single almost ball valve type throttle arrangement.....your theory has creadance we monitor fluid and air flow and using a full bore ball valve compared to a butterfly or seat and plug does make massive difference, can't just find any data that would support it, are you looking at a single body say 80mm feeding 4 cylinders?
Regards
Ian
Regards
Ian
GARETH T,
im sure dave walker (
![bowdown.gif](https://passionford.com/forum/images/smilies/bowdown.gif)
the only production engine i know of which runs roller barrel throttles is the minister built caterham (and i think they are using the same inlet on there zetec cosworths) and thats it! i always look at the top, ferrari dont use it,,, mclaren dont use it, gareth dont use it
Originally Posted by Jano_OddKidd
it is not a roller barrel type and has four butterfly's controled by one shaft. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
What i imagine
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Regards
Jano
GARETH T,
No offence but a Ferrari or Mclaren is not anything like a Ford
IMO you should base your comparison on a better example
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Never tried a barrel throttle myself, but I know of at least 1 guy (kevin Procter) who runs a Puma 4 x 4 using esc cos WRC running gear and engine who has tried both a barrel throttle body and went back to a conventional butterfly type siting throttle reponse with the ALS turned on as the reason....never had an indepth conversation about the why's with him yet!! I like the idea and I if I was desgning a system incorporating a barrel i'd go for multiples rather than 1 large body...it may be the resitance offered by a barrel(s) that prevents smooth throttle response and that's why people have tested then rejected these types of throttles....this aint a new idea we played with slide injection on N/A engines with a major degree of sucess a long time ago.
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Thanks for your replies
Regards
Jano
GARETH T,
IMO you should base your comparison on a better example Maybe a WRC Cos which uses roller plenum
an engine is an engine,,, be it making 10hp or 1000 hp,,, the big boys i talked about have even bigger budgets i think i know who too be lead by
havent ford now binned the barrel inlet on the focus??
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
caprixpack
25-09-2015 07:53 PM
