st24 lack of power
http://www.fordmondeo.org/ubbthreads...&page=2#166385
Hopefully something of help there, looks to be a good Mondeo resource.
Good luck.
Good luck.
look down the right hand side of the engine, under the black cover you will see the actuator arm, with your right hand rev the engine to about 4 k you should see the arm move thus opening the secondaries, if not the control box (where the arm comes out of) is usually the cause as it gets cooked by the heat from the engine about 140 quid from ford and very easy to fit.
also while your there change the water pump to a metal impellor one to save your headgaskets from going tits up!
steve
steve
deathrider666
28-09-2015 06:12 PM
