Anyone got any pictures of an aeroquipped turbo water feed?
Would like to see how you've done it and which way you've routed the hoses. This is with the proper fittings in the turbo and not just the posh banjo clamps on the standard banjo and pipe.
Also can you screw fittings into the 4x4 thermostat housing to take aeroquip. Do they need tapping?
Ta
Paul.
Ta
Paul.
Paul, i will get some pics tonight for you.. you use male to male adapters to go from the turbo to -6
right side is a tight squeeze
also the thermostat, you need a works therm housing like i have... or you can get your std one welded etc
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
