Which gauges are most important?
for argument's sake you can either have 2 or 4 gauges (exclude tacho and speedo from this!!!) ... fuel level is a no no due to lack of sender, and so is boost cos it's a normally aspirated engine... which would you have?
I'm thinking oil temp water temp, oil press, fuel press.
what do you all think?
yeah, well i may worry about that later on, but worth considering.. exhaust will probably cost me plenty of cash, so probably worth sticking the boss in for another tenner or whatever.
out of interst, what's the difference between lambda, EGT and AFR?
I'm guessing ETG is just temp, lambda is the mixture in the exhaust ans afr is measured somewhere inlet side?
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
