Are uprated standard height front springs available 4x4 cos?
Old 21-06-2004, 09:37 AM
SPADGE
SPADGE's Avatar
Default Are uprated standard height front springs available 4x4 cos?
As above
Am looking to raise the front end on my 4x4 3 door as fed up with the front splitter trying to mow the grass when parking in a field lol
If so where from???
Cheers Spadge...
Old 21-06-2004, 09:42 AM
Jim Galbally
Jim Galbally's Avatar
yes
i know koni do a spring and eibach.
i assume that more places do aswell...
however if i had a car as high spec as yours and a big overdraft i'd be tempted by coilovers
Old 21-06-2004, 09:48 AM
Leda will make you springs...any size etc....They are made by a company in sheffield tho, so you might be able to buy direct, but i aint got the number here....
Old 21-06-2004, 10:22 AM
DOO
DOO's Avatar
Still avab from ford
finis 1659817 £42.60 each +vat retail
Not a bad price Would be even better with a bit on discount
Old 21-06-2004, 10:24 AM
DOO
DOO's Avatar
sorry mate did not see the uprated bit
Old 21-06-2004, 10:25 AM
smokey
smokey's Avatar
Leda springs based on Bayjoo spec for 4x4s keep the height standard at the front.
Old 21-06-2004, 10:38 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Spadge,
Yes, AVO do some that I could do just as a front pair.
Old 21-06-2004, 10:42 AM
3drstretch
3drstretch's Avatar
Get some hydraulics mate.Then you can alter it as you go 4x4ing.
Old 21-06-2004, 12:59 PM
manoj
manoj's Avatar
Spadge,
Chassis Dynamics\Avo do a 30% uprated standard hieght spring for the 4x4 & 2Wd cossies.
Mikes your man mate..
Old 21-06-2004, 01:06 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
If you more interested in drag strip than track work then std springs will be better, softer and more squat equals better traction
well, providing, cause of stupid cossie suspension geometry, it dont squat so low it makes too much negative camber, fooking up the grip...
but at std height it shouldnt do
Old 21-06-2004, 02:16 PM
SPADGE
SPADGE's Avatar
Cheers for all the advice fellas
Appart from of course the Batman pimp daddy Stretch
I have some coilovers coming (Billys) but unless they put a bend in the track at the pod i doubt they will be getting fitted
Mike R you have another mail
Old 21-06-2004, 02:20 PM
Jim Galbally
did we learn nothing from danny steve
Old 21-06-2004, 02:24 PM
SPADGE
SPADGE's Avatar
squating is for girls btw
A.t.p
15-08-2015 11:37 AM
Botts
13-08-2015 04:16 PM
dal3door
13-08-2015 06:55 AM
track.focus'd
12-08-2015 05:53 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Are uprated standard height front springs available 4x4 cos?
