Boost Dropped?
it could also be the perpendicular volumicity of the moon which has an incoherant disposition of 25.251
sorry
get a pressure test done on the inlet to determine any boost leaks before you start to wind the actuator back in a bit or it could go very wrong.
also, check that the throttlle is fully opening when the loud pedal is fully pressed to the carpet
sorry
Hi Guys,
Cheers for the replies. I have tried putting a bleed valve on in place of the amal valve and the most it would let me turn it upto was 19psi. Does it sound like the actuator has had it? How do I go about checking that the throttle is opening fully?
Many Thanks
Dan
Many Thanks
Dan
Originally Posted by B19-TRB
Yup!
I loose around 3-4psi on a hot day!
Save Teh Whale!!!212112£!"£!$11
Innit m8!
But then the standard intercooler & location on a s14a is fookin terrible!
but i dont care! its got air con that seems to b more important when its hot than cainin the car round!
it will limit it yes!
wether u have another problem I cant comment! but iw ould say the hot weather will have a good deal to do with it! but the best way to test this is go out late @ night when its cooler!
Just took it for a quick drive and the boost hasnt changed now its a bit cooler
is there any other reason why the boost has dropped this much apart from an air leak or knackered actuator?
Dan
Dan
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
