honda type r clonking noise helpppppp
thers a clonking noise from the front wheels when its on a full lock only when moving but i have changed both iner and outer cv joints and shafts on both sides what else could it be its only when the wheel is turning under load and on a lock postion it does it both ways but worse on the drivers side its a honda acord type r w reg i can only see it being the wheel bearing or hub .or gearbox what do you think
hub has a littel movement and i mean littel but just cheacked the power stering fluid and ther gearbox oil in ther so drined it out and put the proper stuff in ther problem solved but hub will be on the list if it comes back thanks every one that posted
chowfornow
14
05-01-2019 09:01 PM
