rs turbo ecu question????
Alright peeps,
gonna be chipping my missis h reg 90 spec s2 on the weekend and getting her setup.
I'm stumped on a few things though and what ecu to use.
here's the choices :
1) 90spec - hearts/triangle/hash with superchip fitted
2) 90spec - hearts/triangle/hash with performance turbo systems fitted
3) series1 - blue/red/blue no idea of chip, as i haven't checked yet
Also would it be a good idea to swap the black fuel ecu's over aswell that come with each corresponding chipped ecu?
cheeRS in advance
p.s will the hearts/triangle/hash ecu work in a series 1? i have heard people saying it won't, but then i have seen a freinds one running with a 90spec ecu fitted to it?
cheeRS in advance
option 2 IMO!
reason being ive been impressed with S2's with the TS Chip.
Ive not had any experience with the Superchip 1. (doesnt mean its not as good as option 2 though)
I believe that the S1 ECU does not have a knock sensor where as the other 2 will have.
hth
hth
ok what company is option 2 from then is it turbosystems or pts in luton?
are they more likely to both be 195 chipped ecu's?
cheers
cheers
Sorry M8 I didnt realise that you didnt have the chip, I thought you had the choice of 3 Chipped ECU's, all ready to plug in and it was just a case of which 1 to use!
If you are purchasing new then I'd have a look at the following links!
http://www.motorsport-developments.c...es/rsturbo.htm
http://www.turbosystems.co.uk/products_frames.htm
Worth pointing out that the condition of your engine & way that your car is setup will determine power rather that the quoted BHP of the chip!
sorry mate, i do have 3 chipped ecu's, but what i want to know is option 2 a pts item or turbosystems item? I guess its pts as it states performance turbo systems on the chip.
just wanted to double check really.
also should i pair the fuel ecu's aswell that come with the inition silver ecu? So change both together or just one.
cheers
cheers
ok peeps, whatcha reckon with the pts chip or the superchips one
can i fit the s1 ecu to the car without any probs
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
CabrioTurbo
01-08-2015 11:04 AM
