FAO Any Paint Sprayers
Ive been painting my bumper, and im ready to lacquer it, do i just spray the lacquer staright onto the base coat or what? (the base coat alone looks very shiny and is smooth like it has already been lacquered )
Thanks
Thanks
the base coat will need a quick flat of with 1500 wet n dry then another coat before you laquer it or it wont stick properly you cant let the base dry too long
AS Damo said, give it a couple of coats of base, (if your using water based, each coat must be dry or it will "pop") then a few coats of laqure. Let that dry, then polish. Job done!
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
