Why cant u use solid followers on hydralic cam?
i would of thought that hydralic lifters dont like being accelerated hard so the hydralic cam would have a more gental lift rate,
so why cant you use solid lifters on a hydralic cam?
just finding my feet
theres a pickup bit on the lobe for the solids karl said i belive a while ago, he might have been talking about the ramp but i up unitl now thought it was a actual holder bit
pm karl, christian or ollie as they all have experience in solids
Think this is the answer.
Just found on Pipers web site
Ramp: The ramp is the part of the profile that takes up the valve clearance and slack in the valve train gradually, before the valve is actually lifted from the seat. It also rests the valve gently back to the seat after the closing flank. Mechanical profiles use a much larger ramp than hydraulic ones, as the hydraulic cam follower should be in contact with the lobe at all times. The height of the ramp dictates what measurement the valve clearances should be set to.
