HELP!!!!!...fooking swedish plenum and GT35...
Yeah right does the GT35 fit straight on Fooking knightmare.....but it will be sorted...this is the immediate issue can anyone supply a made boost hose????....Its 2wd throttle body (bored out with bigger butterfly ) to a now cut down RS500 size intercooler!
Its not as it looks just a straight hose!!!...The intercooler is lower and to the near side!
not being funny,,, but couldnt you tell the standard hose wouldnt fit?
im with dave,,, take teh intercooler off,, and change the outlet direction
i had a couple of pipes made up in steel by a local exhaust manufaturer, they only charged Ł20 a pipe, try powerflow or summit as they will knock you a bit of pipe out and they can bend it to whatever shape, plus you can use your own silicone pipes to fit either end and then you can weld a bit for your dump valve, actually could lee at fusion not do it for ya
Gareth...didnt think it was a problem as rainbird just said what SECS did at the time ..You can see they never fit anything like this themselves!
I got one idea tommorrow as we do flexable ducting that may work...
Just found a problem phil, reducer elbow only come in 90 Degree bends.
So you may have a problem, doing both reducing and 45 degrees in the same short space.
Maybe someone has found a solution ?
No dont need a reducer as i can just put a piece of std hose inside to fit the throttle body!..Got the metal straight piece with dump take off..but still gonna be tight
Does anyone think that the conduate type heater hose will do?????..Its like alluminium that is fairly flexible...we do that at work....would it be strong enuff?..Cause i could easily make them 45degree bends!
im with dave,,, take the intercooler off,, and change the outlet
direction
direction
timsrs
22
24-09-2015 08:14 PM
