boost limiter
Old Jun 16, 2005 | 05:36 AM
tonyturbo's Avatar
tonyturbo
Default boost limiter
running ofab on a zetec turbo. just running in just now. sometimes on a cold day itl boost to 9 psi ish and it hits what i think is a boost limiter type thing. once it has done this it wont boost. coughs and splutters etc. if you switch it off and restart it, it cures and its back to normal. boost is set with a bleed valve. no amal valve fitted.
does anyone know whats going on.
Old Jun 16, 2005 | 08:20 AM
You sure its not just a misfire?
Try closing the plugs up a touch and see if that help.
Old Jun 16, 2005 | 09:17 PM
tonyturbo's Avatar
tonyturbo
i'l give it a go. does it ebverytime you hit full boost. cuts out nearly an tries to put you through windscreen. al check plugs tho. cheers.
Old Jun 17, 2005 | 07:27 AM
ballin's Avatar
ballin
dunno mate but your s2 looks fuckin lush!!!!!
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
