engine won't pull ???
Old Jun 15, 2005 | 12:19 AM
AndyBlackFRST's Avatar
AndyBlackFRST
Default engine won't pull ???
Running the car earlier and is set to boost to 10psi.
running about earlier, hits boost fine etc.. then all of a sudden the car seems to not pull.. Fuel is ok.. so roll down the road to the petrol station to double check..
Chuck fuel in and still doing this..
The car will boost to 5psi fine.. but as soon as it hits 10, it goes flat.
Any ideas?
Old Jun 15, 2005 | 12:27 AM
Physio's Avatar
Physio
Is it holding boost ................Fooked actuator perhaps?
Old Jun 15, 2005 | 12:32 AM
Stu.H's Avatar
Stu.H
fooked engine?
only jokin mate, hope u get it sorted.
AJ, get on msn!
Old Jun 15, 2005 | 09:39 AM
ballin's Avatar
ballin
sounds like it needs a tune to me
Old Jun 15, 2005 | 11:44 AM
matts1's Avatar
matts1
loose boost hose, slipping clutch, had both of them happen on mine
Old Jun 15, 2005 | 11:47 AM
AndyBlackFRST
Its pulls, then suddently goes really bad.. but fine if you take foot off accelerator..
Was fine til last night
Old Jun 15, 2005 | 12:01 PM
mattbibs's Avatar
mattbibs
not really the same symptoms but when mine hit about 10 psi it used to hesitate and fook about. end of the day it was a faulty chip causing it!
Old Jun 15, 2005 | 12:05 PM
AndyBlackFRST
sounds like mine is doing.. but i don't have a chip in mine.. hmmmm
Philly's Avatar
Philly
Default Re: engine won't pull ???
Any ideas?
Have you just built it, or is this a problem thats just happened over night?
Old Jun 15, 2005 | 12:06 PM
AndyBlackFRST
Its just ahppened last night.. have been driving for about a week with no problems
Old Jun 15, 2005 | 12:09 PM
Philly's Avatar
Philly
and you havnt changed anything since it was running with no problems?
Old Jun 15, 2005 | 12:17 PM
AndyBlackFRST
nothing at all.. ran fine most of my journey.. then developed this fault
Old Jun 16, 2005 | 12:55 AM
AndyBlackFRST
Had another run tonight to try and figure out what is happening..
when i press the accekerator, the revs drop to start with...
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
