Std Mk 5 rear tailgate.. still available from ford?
Need a std Mk 5 tailgate NEW
are these still available?
anyone got any ideas on how much they cost?
cheers
Dave
cheers
Dave
I got a new Esc Cos one from ford in 2003 cost me Ł296.11 part code 6765332 (from reciept) if anyones interested I will dig it out and get some photos.
1 Post
Originally Posted by GUZZLER
the later mk5 (non cossie) also had lights in the tailgate.
guys, mine hasnt rusted.. i need one without the holes.
does the tailgate come with glass?
cheers for the finis codes.. does anyone know for sure which tailgate will fit the esc cos?
i really dont want to fill the original holes / wiper hole and i REALLY dont want to go to a scrappy to get one.. id much rather pay the extra for brand new
Gareth.. do you mean rear lenses???
1 Post
the finis codes are as for as stated
the only difference is that the no cos ones doesnt have the holes for the spoiler but does have the wiper and wash holes which are blanked with a plastic grommet if not used, no glass IIRC, just the tinwork in grey primer.
Dave,
You need a mk5 tailgate...all the esc cos's we've built use the mk 5 tailgate....tailgates dont come with glass...they will all fit the esc cos...your new wrc spoiler wont fit on a mk6 tailgate....
Car looks well mate...
Regards
Ian
Regards
Ian
thanks Dave, appreciated
Ian, yes pal, i wasnt in any danger of ordering a Mk6 tail. Thanks for the comment on the car too should see a lot more work on it soon
out of interest Ian, of the cars you build.. do you ever use an in tank pump? im currently replacing mine with a bosh 023 item and want to use aeroquip hose from the two unions projecting from the tank.. im guessing i just need to get -6 male fittings welded / brased to these pipes?
Dave,
We use a boot mounted bag tank...2 separate pumps
The in tank mod was something we did wen we built grp 'n' cars....that was a long time ago and i cant just recall how we put them together....the method you describe sounds fine though....we tend to silver solder mods to fuel components/rails etc....
The new car was painted last week....and before you start to give me s**t the colour was decided a long time ago.....
Regards
Ian
Regards
Ian
Ian, that is quality! now the question you probably visioned....
those front wings.. are they steel and where did you get them from (although I suspect you will say they came with the shell)
im going to pull my finger out and actually get a set of steel wins and get them sent to be hand beaten and sprayed if i cant source any
They are kevlar mate....we get them from a guy in Darlington...all the panels on the car except the rear quarters are composite....Ramsport 01824 70 70 38 had a set of genuine steel wings for sale...i thought i'd sent you the info....
Regards
Ian
Regards
Ian
Its he same old thing....up close they won't look as good as the steel wings......on an old rally car you expect the door gaps to not quite line up (adds character)...but on a minter like yours i'd be sending them to Gordy Vincent and having some genuine steel versions done....I took this pic to try to show how wide the WRC car is compared to the normal esc....unfortunately i'm not that adept with the old camera....
Did they give a price for the carbon wings?
Regards
Ian
Regards
Ian
Ian, that IS a lot wider than a std esc! If you werent so far away, id deffo nip up for a brew and a look at that whats the plan for it?
Gordon Vincent? is he the guy that hand beats them? Do you have his details, or company name and location?
Its a Gravel Spec WRC Car....we were hoping to do this years BTRDA in it but funds have been tight so it looks like it will be next year..the car has been trial built so its just a case of nailing it all back together in the next couple of weeks...
All the usual stuff...6 speed active FFD box...active 8.5" front diff.....WRC engine 8 inj..ihi turbo....fuel safe bag tank...proflex...aluminuim prop...fabrictaed 6 point front x-member...shell as light as we can...
Gordon Vincent is the guy who did all the Boreham Fabrication work...his company ACS engnieering is in Witham...01376513419...when he does the wrc shells he cuts the rear inner arches and pulls them out by about 1".....they then as you say roll and beat the fronts....he did the cage, mounts and pickups on this shell and although it wasn't a new shell its a work of art...
Rear suspension and cage pick-up points...
Regards
Ian
Regards
Ian
Ian, that looks superb! all the best in getting it built and stage ready! I think ill give the guy a call and see if he can source and mould me a pair of front wings!
are they easy to fit ??
To change em if (wen) we batter em we bolt the from wings....but you could easily bond (sikaflex) them on...I think i paid about Ł150 a piece for the kevlar wings....Ł300 is taking the piss....if you have no joy and still want some I can see if i can get you a pair....
regards
Ian
regards
Ian
Those pics are stunning, to the un-trained eye it amazing just how much of a difference there is between a standard Escort Cosworth and a WRC Version!
Can a WRC Version be made from a road going Escort Cosworth or are the WRC shell's different to start with?
Pics look simply stunning mate!
Dan,
You could convert a standard road car to WRC spec but it means a strip down to a bare shell...
The rear arches are widened by about and inch from standard as are the fronts...
Glad you like it...
Regards
Ian
Glad you like it...
Regards
Ian
Cool thanks for reply!
Car looks the nuts mate, are those recent pics or have you got any further with it now, would love to see more!
Sorry for the spamming Dave!
I sourced a mkV tailgate with standard tinted glass and lock/key for mine when I was going to WRC it. It is in good condition, debadged, diamond white.
Its surplus to requirements now and taking up valuable space, so PM me if you want it cheap.
Nice WRC pics BTW - that fatarse is lovely, much meaner than a std escos.
Newts
Newts
155lee
14-09-2015 07:37 PM
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
