Boost gauge fitting
Old Jun 8, 2005 | 08:07 AM
Franco's Avatar
Franco
Default Boost gauge fitting
Where's the best place to take a feed from on a Esc Cos???
Remembering i haven't got a clue on cossies
Old Jun 8, 2005 | 08:44 AM
Alvyn's Avatar
Alvyn
from the inlet manifold,not from the fuel regulater or map sensor pipes take fed from the other pipe that's left
Old Jun 8, 2005 | 08:47 AM
Franco's Avatar
Franco
Don't suppose anybodys got any pic's.................I fooked under this bonnet
Old Jun 8, 2005 | 09:28 AM
Franco's Avatar
Franco
Boink!
Old Jun 8, 2005 | 10:19 AM
rs cos's Avatar
rs cos
I would just put a t piece on the back of the standard one in the dash! what you doing all the way out there under the bonnet in the cold
Old Jun 8, 2005 | 10:21 AM
Franco's Avatar
Franco
Think that one might be giving a false reading at the moment........
And my Gready one looks much more bling!
Old Jun 8, 2005 | 10:26 AM
rs cos's Avatar
rs cos
well dis connect the pipe off the back of the standard gauge in dash and take the other end of it off at the inlet manifold and blow air thru it and make sure it's clear, then if it is put a t piece on it at the back of the gauge in the dash plug it back in then run the other side of the t piece to your new gready gauge. you will have two boost gauges then and you will be able to see if the original gauge is faulty or not!. also you could plug the end of the vacum hose when you have it off at the inlet manifold then send air thru it from behind the standard gauge in car and listen for air leaks this mite explain faulty gauge reading!
Old Jun 8, 2005 | 10:37 AM
Glenn5's Avatar
Glenn5
yep thats where i teed mine in2 bugger opening the bonnet. everytime i open the bonnet it costs me money
Old Jun 8, 2005 | 10:39 AM
rs cos's Avatar
rs cos
Old Jun 8, 2005 | 10:47 AM
Franco's Avatar
Franco
Nice one lads!
Kyle Langford
27
Aug 5, 2019 07:54 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
mrmann
Aug 20, 2015 11:24 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
