computer experts plz help?
Old Jun 5, 2005 | 03:02 PM
escort-cossie-owner's Avatar
escort-cossie-owner
Default computer experts plz help?
when i turn my comp on i get a blue screen with UNMOUNTABLE BOOT VOLUME
any1 know what this is as i would like to know
thanks
Old Jun 5, 2005 | 03:08 PM
ballin's Avatar
ballin
you aint left a floppy in have you?
(thats the extent of my knowledge btw )
Old Jun 5, 2005 | 03:10 PM
escort-cossie-owner
nope nothing in the floopy mate
just bugging me now
Old Jun 5, 2005 | 03:12 PM
Adrian's Avatar
Adrian
Added any new hardware?
What OS should it be running?
Old Jun 5, 2005 | 03:16 PM
escort-cossie-owner
no new hardware added
os is xp pro
Old Jun 5, 2005 | 03:22 PM
EIL132's Avatar
EIL132
Boot from XP cd and when you see the Welcome to setup press the letter R. You will get a dos prompt, type chkdsk /p and hit enter then type fixboot and hit enter. When asked type y.
Old Jun 5, 2005 | 03:27 PM
Cossie-Lee's Avatar
Cossie-Lee
Hi, iv had this problem a few times, its probably because your boot.ini file is messed up.
Do you have the WinXp disk?
If so, try this-
boot to the XP cd and when you see the Welcome to setup press the letter R
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows
This error can sometimes occur when a new hard drive has been fitted to an older computer, have you installed a new drive?
Hope this helps,
Lee
Old Jun 5, 2005 | 03:28 PM
Adrian's Avatar
Adrian
As above.
But I think I use fixmbr instead of fixboot.
Old Jun 5, 2005 | 03:29 PM
Cossie-Lee's Avatar
Cossie-Lee
someone just replyed with the same answer,
Sorry
Old Jun 5, 2005 | 03:42 PM
escort-cossie-owner
ok guys so if i put the xp disc in you get the install page come up
what do i do then as it asks what u want 2 do e.g install xp or check compatibility
Old Jun 5, 2005 | 03:47 PM
Adrian's Avatar
Adrian
You have to boot the machine from the XP CD.
Old Jun 5, 2005 | 03:51 PM
escort-cossie-owner
how do u do that
im realy no good with comp
Old Jun 5, 2005 | 03:58 PM
ballin's Avatar
ballin
put the cd in the drive, then reboot.
as the computer starts enter the bios (usually by pressing "del", "F1" etc etc") then set the startup sequence to look at the CD drive first
Old Jun 5, 2005 | 04:01 PM
escort-cossie-owner
wow to techy 4 me in english first
whats bios etc
sorry guys
Old Jun 5, 2005 | 04:52 PM
ballin's Avatar
ballin
ok as you start your computer, look for a message that says "press DEL to enter setup" or "bios" something like that.
if you dont see it just press DEL and F1 and you should enter the bios.
in there look for something that says "boot sequence" or something along those lines, it will probably say "A:\, C:\" change it so "CDROM" is first!
AJC
Oct 1, 2015 06:47 PM
DavidK
Sep 27, 2015 02:55 PM
Kam B
Sep 24, 2015 10:40 AM
