Cossie Camcover breather fitting.....Brom and other gods :D
Team HOTHOT!
what thread is it where you drill the camcover to put a fitting in - do you use 3/4 BSP or something slightly smaller?
cheers n beers
cheers n beers
gracy speek english man
you want a breather fitting to ya cam cover or you want to tap it and thread it in there
or you drill the back out and weld in a fitting
personlly i would weld one in there but some ppl epoxy resin one in
tube diameter is 16mm depending on breather system
Team HOTHOT!
cheers Brom - i was refering this:
when you take the camcover off and look at the underside of it, at the back near #4 plug hole, there is a hole that is cast into the camcover - this can be drilled right the way thru - i need to know what size thread will be the maximum to fit in there failing that, i'll have to take the breather pip from elsewhere in the cover and get a block welded in so i can tap it out and use a nipple to fit whaterver size i will use
