boost pressures
Old Jun 17, 2004 | 12:59 PM
skeld's Avatar
skeld
Default boost pressures
my S2 is currently peaking at around 17psi and holding 15psi. should it peak at 17 and hold the bosst at 17? at the moment am i running 17psi or 15psi?
Old Jun 17, 2004 | 01:03 PM
Jim Galbally's Avatar
Jim Galbally
2 possibilities...
1) your car can happily hold 17psi but your actuator's gone weak and youre dropping the boost top end.
2) its been set up lik that on purpose to provide a nice torque increase when you stamp on the throttle, but safer high up the rev range. (v. common)
did you buy the car like this? or have you taken it to a reputable tuner?
Old Jun 17, 2004 | 01:05 PM
CabrioTurbo's Avatar
CabrioTurbo
wot jim said.
when i had my old engine in the cab i set it up to run 25Psi peak.. it would however drop off to about 17Psi.. main benifit was that you had a LOT of power for overtaking.. and with my 2 stage boost i didnt have to run it like that all the time.
Old Jun 17, 2004 | 01:09 PM
skeld's Avatar
skeld
i brought the car like that. so this is fine then?
Old Jun 17, 2004 | 01:10 PM
Lemon S2's Avatar
Lemon S2
Mine peaks at 25 but holds 23 and this is on quite a new actuator. I think that's the way most of them run so you should be too worried. IMO i's say that you was running 17psi but other people may have different views.
Old Jun 17, 2004 | 01:11 PM
Jim Galbally
if you bought the car like it is then you have no way of knowing the previous owner had it set up correctly.
IMHO i'd take the car to a tuner as soon as poss n get it set up pukka...
for all you know it could be perfectly fine, but with modified cars you never can tell so its a good idea to do it for peace of mind
Old Jun 17, 2004 | 01:12 PM
Jim Galbally
id' say "peaks 17, holds 15" lol
Old Jun 17, 2004 | 01:51 PM
skeld's Avatar
skeld
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
