smoking s2, pls help
hey guys n gals,
me s2 has started to give out blue smoke n i was wonderin if ne1 can help as to why, EVERY time i start her, HOT OR COLD, she smokes (1 puff as if valve stem seals), and i get a puff floating by my window in traffic now + then, it rarely smokes on idle, or overrun, just when i blip the throttle quickly to say 1500-2000 rpm.
new turbo?valve stem seals? rings?
did a comp test a few weeks back and the dry test was 150 + wet test was 160, constant through all cylinders
cheeRS
dre
cheeRS
dre
ooops.... forgot to say, i had the same problem on start up (puff of blue smoke) it was the valve stem oil seals!!! i'd try these first as are a lot easier to do than rings etc...
hope you get it sorted.
hi mate, when you check the impeller remember it floats on oil so thay will be a very slight movement ther side to side but hardley any, but nothin up and down, ive done the job twice, when it comes to smokin rs turbos its nrearly always the turbo
andzz
andzz
Steve Escos
01-10-2015 06:57 AM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
