Changing dials/clocks PLEASE HELP
Old Jun 1, 2005 | 11:11 AM
gingeRS's Avatar
gingeRS
Default Changing dials/clocks PLEASE HELP
i'm in the middle of re-doing my dials in my s2 to make them look better. the standard black faces look horrid as the paint is flaking off, on the numbers and temp gauge
i have removed the clocks, the cover (clear bit), and the 8 or so screws securing the front bit (black) to the back (white) part
it doesnt come apart. its cos the needles are fixed the the front and back casings?
where do i go from here? remove the needles? how, any tips
also is it still possible to get gauge faces from fords, i dont like white dials much, and mine are falling apart
cheers guys
top marks for a speedy response, as i'm on someone elses computer
Old Jun 1, 2005 | 11:14 AM
Oranoco's Avatar
Oranoco
Take a fork from the kitchen drawer and slide under the needle. Lever the needle of gently and fit white dial. Re-fit needle ensuring you get it back in the right position. IIRC some kits don't require the removal of the needles. I know the ones I did on the XR didn't
Old Jun 1, 2005 | 11:20 AM
gingeRS's Avatar
gingeRS
dont i have to remove the black clocks? or do thewhite dials go over the old ones? how do they light up if thats the case?
if i lever the needles of gently with the clok unit come apart. as i wanna take it to bits
cheers for the fast reply steve much appreciated
Old Jun 1, 2005 | 12:26 PM
Dave_RST's Avatar
Dave_RST
When I fitted mine the hole in the middle of the white dials was big enough to slide them on without taking the needles off.
If I remember correctly I just cut the old dials off with a stanley knife.
Old Jun 1, 2005 | 02:24 PM
CabrioTurbo's Avatar
CabrioTurbo
youve got 2 options really... you can either stick the dials over the old black ones.. they will light up ok. you can do this without removing the needle as the hole in the middle of the dial is big enough to get over without having to remove the needle
OR you could if you can be arsed cut the old black dial away using a knife, the only problem doing this is they are PROPERLY stuck on and trying to remove the glue stuff underneath can be a nightmare.
CheeRs
Phil
Old Jun 2, 2005 | 03:22 PM
gingeRS's Avatar
gingeRS
i just wanna know how to seperate the front and the back cases
so i can get in at the dials, dont mind a bit of hard graft as doint use the car at the moment anyways
anyone fitted white dials, and removed the old black dials from behind
any pics etc
will i be ok if i note where the needles where, on a picture then just pull em off, or is it more trcky than that?
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
