cossie help needed
Old May 30, 2005 | 10:56 AM
Dicko&Vacant's Avatar
Dicko&Vacant
Default cossie help needed
was out in my car last nite was running spot on then i put my toe down in 3rd came on full boost and then an almighty pop which i thought was a boost pipe blowing off pulled over car only running on 3 cylinders no pipe off so crawled home. had a look today everything seems fine compression is slightyl down on the clyinder thats missing but only by 20 psi oil pressure is fine no smoke at all so could i off bent a valve? or anyone have any other ideas to what i have broke.
dicko
Old May 30, 2005 | 11:51 AM
rapidcossie's Avatar
rapidcossie
sounds like something had melted but this usually happens in higher gears?
Old May 30, 2005 | 12:35 PM
Graceland's Avatar
Graceland
Team HOTHOT!
check your plugs - number 3 or 4 will possibly have melted off
Old May 30, 2005 | 01:43 PM
Dicko&Vacant
just took rocker box off and the exhaust cam has snapped clean in half the cam cap bolts had come loose.
Old May 30, 2005 | 01:45 PM
Graceland's Avatar
Graceland
Team HOTHOT!
would like to see a picture of this please
Old May 30, 2005 | 01:55 PM
Dicko&Vacant
ill go take 1 now for u
Ginge !'s Avatar
Ginge !
just finding my feet
fook, thats not good
did it make a rattle nose coming down the revs as mines doing that and comming from the zorst cam
woodford or pj for the new valves as there the cheepest and if ya a memeber of rsmania ya get a discount of 10%, costs 10 quid to join too
Old May 30, 2005 | 02:11 PM
Dicko&Vacant
Old May 30, 2005 | 02:12 PM
ImaRacing 700's Avatar
ImaRacing 700
flocking hell!
Old May 30, 2005 | 02:14 PM
big_wig_074's Avatar
big_wig_074
was about to say this!exactly the same happened to me fella,i just got the cam changed at SCC never happened again!
Old May 30, 2005 | 02:15 PM
Ginge !'s Avatar
Ginge !
didnt ya break the car
what does the nosie make though !!!!!
Old May 30, 2005 | 02:21 PM
Dicko&Vacant
there was no rattling mate just came on full boost in 3rd and an almighty bang u can see where cam has hit inside of rocker cover lol hopefully hasnt bent any valves good job ive got sum bd10s coming lol
Old May 30, 2005 | 02:25 PM
big_wig_074
ginge,that didnt kill it,the bottom pulley did! that cam snapping happened EXACTLY the same,although mine had bd16s not 10s in it,never happened again in the following 5000 miles i had the car!
Ginge !'s Avatar
Ginge !
ya gonna have a fooker for exchange now
is the comp down on number 4 ????, if so the valves are bent
Old May 30, 2005 | 02:27 PM
Ginge !'s Avatar
Ginge !
your luck with that engine was soo bad
bd16 cams , pm me the spec as i may copy it as i want a decent engine , i know that engine done well at top speed
fook knows what mi noise is then
Dicko&Vacant
me mate brought a proper compression tester cos the 1 i have is fooked and was down 10psi to the other 3.
Old May 30, 2005 | 02:29 PM
Ginge !'s Avatar
Ginge !
it sounds like its nipped the valves and the aint flly shutting
Old May 30, 2005 | 02:31 PM
Dicko&Vacant
so will it be worth waiting for cams to come and try or just take head off and get it checked?
Old May 30, 2005 | 03:00 PM
plynchy's Avatar
plynchy
Bad news fella!
Personally i'd get the head off. Have got some used valves here,bargain.
Old May 30, 2005 | 03:12 PM
Ian M's Avatar
Ian M
mine did exactly the same in more or less same place. i just put another cam in and it was spot on i wouldnt take the head off just replace the cam.
Old May 30, 2005 | 03:30 PM
Ginge !'s Avatar
Ginge !
plug up the the zorst port and attempt to preasurise the cylinder and see if hear air come out
its obvioiusly not much if its 10psi tbh, when theres more worry
Old May 30, 2005 | 03:36 PM
Dicko&Vacant
cheers lads i think ill just take my chances and try the new cams first
where were u yesterday plynchy money grabbing again lol
Old May 30, 2005 | 03:42 PM
plynchy's Avatar
plynchy
Nope,had some friends up for the weekend,got Stella'd all afternoon in the garden!
Graceland's Avatar
Graceland
Team HOTHOT!
blimy - thats the first time i've seen a cam snap
slap some new ones in and hope for the best
Old May 30, 2005 | 03:47 PM
Dicko&Vacant
_________________
my thinking exactly
Old May 30, 2005 | 03:49 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Old May 30, 2005 | 03:54 PM
Ginge !'s Avatar
Ginge !
_________________
my thinking exactly
when i fooked me gearbox in me cabrio i turned the ignition off, let it cool down and then tried to start it again hoping the earbox would work again, never happened
so i then phoned up loads of different mechanics for quotes and explained the issue and all of em said i need a new gearbox except MR Clutch who said the clutch was fooked
so being the tight idiot i am i took me car there toget a new clutch, they fitted one and reskimed the flywheel and then told me the gearbox is also fooked
anyway i refused to pay as they couldnt show me my biusted clutch as they binned it and got it towed to a place that swoped the gearbox, loom, engine ect for the one on me fooked erst and 7 days later i got banned for speeding
theres no moral there but as ua feeling shite i thought i would give ya a laugh
Old May 30, 2005 | 03:56 PM
Dicko&Vacant
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
