-31 actuator
Old May 23, 2005 | 04:02 PM
Hrsturbo's Avatar
Hrsturbo
Default -31 actuator
what way do you wind the rod to turn up the boost? I just put it on and only boosting to 2psi without the amal valve.
cheers
Old May 23, 2005 | 04:09 PM
Rhys's Avatar
Rhys
2psi You should make more boost than that even with a -31 wound all the way out, i would have thought Is it pretentioned etc?
Old May 23, 2005 | 04:14 PM
Hrsturbo's Avatar
Hrsturbo
I wound the rod all the way on and wound it out till I could fit it over the pin. is it meant to be pulled over tight or more rod thread exposed?? Its a brand new -31 actuator so I doing something wrong
Old May 23, 2005 | 04:19 PM
Ham Sandwich's Avatar
Ham Sandwich
Hello,you make the rod shorter for more boost so turn it clockwise.Ideally you want to put the arm over the wastegate arm so you see half the arm top through the whole.
Old May 23, 2005 | 04:22 PM
Hrsturbo's Avatar
Hrsturbo
so you got to pull the arm to get it to hook on the pin?? so the shorter the arm more boost and harder it is to get on yeah?
Old May 23, 2005 | 04:26 PM
Ham Sandwich
You are indeed correct Sir,but dont turn it up too much!
Old May 23, 2005 | 04:30 PM
Hrsturbo's Avatar
Hrsturbo
cheers won't turn it up, will let the tuners do that
Old May 23, 2005 | 09:29 PM
Stu @ M Developments's Avatar
PassionFords Creator
Famous last words before the Noise and smoke begins......
Old May 23, 2005 | 09:41 PM
Azrael's Avatar
Azrael
Which noise? There are some we do like Don't we?
I got just below 1.4 bar with my -31 today and it's very hard to put it on the pin now... but will have to to woundit up one or two turns more
Old May 23, 2005 | 09:48 PM
Dont overload it or you will find huge boost probs at high rpm when the boost starts to climb on its own
Old May 23, 2005 | 09:52 PM
Azrael's Avatar
Azrael
At high rpm it tend to fall as you know I have the huuuge T25 under the hood
But I know what you mean and I am aware of that.
Boost-control-wise I am only worried about the boost solenoid - how to check if it does anything? Unplug it? What would happen?
It does this "bzzzzzzzzzzzzzzzz" sound at idle, is that right?
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
