Spark plug gap when using coil pack
May 20, 2005 | 12:17 PM
Really sorry if this has been covered a thousand times before.
Whats the standard plug gap for a turbo'd motor when running a coil pack?
Standard ERST gap is 0.7mm.
Thanks
May 20, 2005 | 12:25 PM
May 20, 2005 | 12:26 PM
Is the spark not likely to get blown out with a gap that big?
May 20, 2005 | 12:28 PM
not if your using a coil pack no. Thats what everyone uses s far as i know, AB, EA, MSD...
May 20, 2005 | 12:45 PM
I run a 1mm cap on on a coil pack setup, no problum
Steve
May 20, 2005 | 01:20 PM
depends on cylinder pressure but go for the biggist you can
May 20, 2005 | 01:24 PM
Will i need to get it set-up immediatly after changing to a larger gap??
It was mapped with the coil pack but only a 0.7mm gap.
Thanks.
May 20, 2005 | 01:31 PM
why?
is there a problem with it running .7mm
May 20, 2005 | 01:32 PM
No problem at all, but may as well make full use of the coil pack
May 20, 2005 | 01:39 PM
true.
You should get the A/F checked after changing gap though.
I would consider a remap as well to be on the safe side of risk/reward!
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
