ABS relay / brake problems HELP
Old May 20, 2005 | 08:17 AM
cossymad's Avatar
cossymad
Default ABS relay / brake problems HELP
I have no brakes as all the relays are missing from the car.
Which, or where does the ABS relay go how do I bypass it to get the ABS pump to kick in and then I can bleed the brakes, so I can stop!!
I have bled the front's OK, but the rears need the ABS pump to push through the fluid, and also with no pump there is no servo assistance, so shit hard pedal on un-run-in brakes with very hard pads
Help me
Old May 20, 2005 | 08:56 AM
cossymad's Avatar
cossymad
Perhaps I should have asked ''Do you like Macdonalds or Burger king better??
i didn't though because it's so obviously BK
Old May 20, 2005 | 10:26 AM
Wazzzer's Avatar
Wazzzer
I thought they were in the boot on the drivers side?
yatta
May 21, 2016 10:31 PM
15
Oct 7, 2015 03:43 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
