High ohm injectors
Old 21-05-2005, 09:11 PM
  #41
ECU Monitor Enthusiast
b19bal, Okey dokey no problem
Old 21-05-2005, 09:15 PM
  #42
DazC
DazC's Avatar
You do like to waffle a little though Ginge!
Old 21-05-2005, 09:21 PM
  #43
extra14
extra14's Avatar
Just one question, i take it you need the low injector resistance as the ecu will throw out an error code?
Darren
Old 21-05-2005, 09:26 PM
  #44
Weber ecu's (L1,L2,L6,L8,P8) cannot detect injector faults
Most aftermarket ecu's do have fault diagnosis on output drivers.
For example, on my S8 ecu, in 8 injector mode, if one injector fails, the coresponding paired injector
is switched off to prevent unbalanced fuel delivery.
A fault code is also stored and a RPM/BOOST limit is set to protect the engine.
Old 21-05-2005, 09:40 PM
  #45
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Its a pleasure to listen to you guys chat tonight, so Simon, Darren, take a bow
Old 21-05-2005, 09:48 PM
  #46
Cheers boss man
Old 21-05-2005, 10:08 PM
  #47
extra14
extra14's Avatar
So then you don`t really need to lower the resistance of the of the injector?
If no fault code is thrown then it should be ok then?
Darren
Old 21-05-2005, 10:18 PM
  #48
turbodisplay,
You are right to an extent, the weber ecu does not know at a software level what is happening with the injector driver stage.
However, from my experience of factory weber ecu's...
When using high impedance injectors on them without any form of matching,
the driver stages usually does 1 of 4 things...
1) work fine - no problems
2) fine control at small pulse widths is impossible.
3) give random pulse widths as the current foldback function gets confused.
4) the output stage latches up. I.E switches on and does NOT switch off !!
Any of the above can happen and sometimes it varys day to day.
I am sure you know this already but the golden rule at the end of the day is to
use the right injectors on the right ecu to be safe !
Old 22-05-2005, 08:25 AM
  #49
extra14
extra14's Avatar
Cheers stu.
Darren
Old 22-05-2005, 09:22 AM
  #50
lancia delta 6 times WRC
lancia delta 6 times WRC's Avatar
All 16v Grales use Weber ECU's and high imp injectors, I guess they are slightly different inside then?
Old 22-05-2005, 10:22 AM
  #51
lancia delta 6 times WRC,
I have sold many S8's to Lancia owners
Old 23-08-2005, 09:15 PM
  #52
GT2
GT2's Avatar
Well.. high imp injectors is now tried..and it worked great with no problems what so ever.
Old 23-08-2005, 09:25 PM
  #53
GARETH T
GARETH T's Avatar
GT2, cool mate,, what spec are you running,
did yo use a resistor like simon said?
Old 23-08-2005, 09:40 PM
  #54
GT2
GT2's Avatar
Not my car actually, but tried on a fairly standard engine.
Ported head, standard cams, 480 hp Turbonetics turbo, slightly lower comp.
630cc injectors and no resistors...
It goes really well actually.
Old 23-08-2005, 09:58 PM
  #55
markk
markk's Avatar
so what is the impedance on the injectors, and on what ecu ?
sounds cool - or is it hot ??
how long have they been in for ?
Old 23-08-2005, 10:23 PM
  #56
GT2
GT2's Avatar
It's a lvl 6 ecu, the injectors are 12 ohm and has been in from this spring.
The cars is used as an (almost) everyday ride, and does many hard trackdays during the season. It used to run greys.
Old 24-08-2005, 04:32 PM
  #57
markk
markk's Avatar
nice one pal - well done
mk3ste
17-10-2021 10:09 AM
Mark_
14
16-01-2016 05:27 PM
01-11-2015 06:53 PM
Quick Reply: High ohm injectors
