problems with brakes
Old May 19, 2005 | 09:03 PM
jonesymk2's Avatar
jonesymk2
Default problems with brakes
im having problems with the brakes on my mk4 escort estate im doing up,ive fitted the brakes that were on my s2 erst which is a 4x4 cossie setup,the estate was a 1.3 ive kept the servo on the car but put the rs master cylinder on,ive also put the rear brake compensators on aswell,ive bled the brakes about three times manually and also put an easy bleed on it 2 times and it seems to hav got all the air out of the system,ive nearly filled a 2 litre bottle from bleeding the brakes
now the problem is i still cant get any feel in the pedal,ive taken it for a drive round the block and the pedal goes almost to the floor b4 the car stops but then every now and then the pedal only went down a little bit and it stopped fine,anybody got any ideas please,also in the 2 rear brake lines under the bonnet just b4 the pipes go under the car there is two little cylinders 1 on each pipe,has anybody got any ideas what they might be for and would they maybe part of the problem
any ideas or suggestions will be much appreciated,im hoping to be putting the engine out of the rs into the estate over the weekend but would prefer to hav the brakes sorted b4 the engine goes in so its 1 less thing to hav to worry about
Old May 19, 2005 | 09:17 PM
NUTS RuS's Avatar
NUTS RuS
Does it have ABS ?
Old May 19, 2005 | 09:20 PM
jonesymk2's Avatar
jonesymk2
no the abs isnt going onto the estate
Old May 19, 2005 | 09:26 PM
NUTS RuS's Avatar
NUTS RuS
The 2 little cylinders are pressure reducers for the rear - leave them on if you can.
Are you sure all the air is out of the system ? Did you bleed them diagonally as that is the way they are piped up.
Any leaks anywhere ?
Is everything tight etc etc ?
Old May 19, 2005 | 09:39 PM
jonesymk2's Avatar
jonesymk2
if they r pressure reducers do i still need the compensators on the car then
no i didnt bleed them diagonally,i did the o/s/r 1st then n/s/r then o/s/f and then n/s/f last,would that be the reason then
everything is tight and ive checked for leaks 2 or 3 times and theres no leaks
Old May 19, 2005 | 09:52 PM
NUTS RuS's Avatar
NUTS RuS
Theoretically shouldn't make much difference but its a prefered method for some people to bleed diagonally. To do it properly its a 2 man operation. One on the bleed nipple and one on the pedal.
Yep leave them on too....
Old May 19, 2005 | 10:00 PM
jonesymk2's Avatar
jonesymk2
ok i will leave the compensators on then,i will try bleeding the brakes that way then,if i get chance i might pressure bleed them with a proper pressure bleeder weve got where i work,cheers for the help its much appreciated
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
