Photographic people! Question?
whether the photo is taken with a wide angle or telephoto lens has no relation to the print size as that depends on the format the photo is taken on
if its any help though aps cameras use the following sizes generally
classic 4x6
hdtv/group shots 4x7
panoramic 4x10/11
classic 4x6
panoramic 4x10/11
To clarify, if you have a 35mm camera, the print will have a 4x6 ratio, if you use medium format, the ratio will vary depending on the camera, but iirc, it is typically square.
Cameras that take so called "panoramic" shots (some APS cameras do it), actually take a full size picture (4x6) and store information on the magnetic strip at the back of the film that instructs the printing machine to crop the top and bottom of the picture to give it a "panoramic" feel.
Stu, to answer your first question (or was it second ?), I think it's a stupid question but stand to be corrected
I wanted to know the dimensions so I can crop some images I have taken to the correct dimensions. Ie pictures I have taken with it in mind of it being printed as a panormaic. But as I dont have a wide angle lense its in the normal 4x6 size and need cropping to the correct size for the photo lab people.
I dont wanna spend more money gettin a picture made to the exact dimensions when I can just crop one to the correct dimensions first time.
Originally Posted by MadMac
But as I dont have a wide angle lense its in the normal 4x6 size.
Crop picture to correct size.
Or am I the only person that seems to understand what I'm saying
Si B
12-09-2015 06:49 AM
andrewmctiernan
08-09-2015 03:05 PM
