Rising oil level
Rising oil level
checked my oil the other day and my oil level was 4cm over the max mark. me thinks over feuling , what do you think is the cause
any comments appreciated.
Thanks
Dave
Thanks
Dave
Dave,
Just in case you didnt know (and from my experience) ....
You should ONLY ever check a cossies oil level or add oil when left over night and the engine is completely cold.
This is the ONLY accurate way of checking level.
This is because the head holds a lot of oil which takes time to get back to the sump.
It is all too easy to over fill when the engine is warm.
as said above and o/fueling which is the worsed due to bore wash OR sumones filling it without your knowledge!
pull d/stick out and have a smell m8 if it smells of petrol it will need to be sorted asap.
No water loss. mate of mine said that when i came past him it was chucking out a lot of black soot ect, then the next day i noticed a smoky exhuast thats what made me check the oil .
Dave
Dave
Dave
Dave
check the map/ct sensors also
Proven Legendary Status
Re: Rising oil level
Thanks
Dave
Thanks
Dave
dave green,
Before you start changing gaskets or regulators.....
Change the oil, let the engine cool down over night. top up as reqd.
Drive the car for a few days and ONLY recheck the oil every morning when
the engine has been left overnight and is stone cold.
If the oil level starts rising then you deffo have another problem
If the old oil stinks of fuel when changed then you may have a problem BUT
it takes alot of fuel to make a noticable level change in the oil.
Originally Posted by SECS
dave green,
When petrol mixes with oil it will turn it very watery almost straight away and the oil will loose it's lubricating properties.
This is why massive overfueling and borewash is very worrying IMO
Dave
Dave
Took it to A1 rally sport steve checked it over, put his pectel monitor on it everything ok, Gave it an oil and filter change. put in 3.6 litres of oil .as autodata recomends, dident seem enouth so put in a bit more 4 litres. did notice water loss but no water in the oil. could be a coincidence. steve advised to drive it steady and keep an eye on the oil and water levels.
Dave
Dave
Simon(secs) Tony at TS told me that the best time to check the oil, is when its warm. He said pull up at petrol station, fill up, pay for the fuel and thats about then the right time to dip the oil! This makes your theory flawed Whos right, you or Turbosystems?
i have always checked my oil in that way Damo....as then you have the oil level while the engine is fully lubed....but Tony confirmed it for me when i went there!
I always check my levels when the engine is stone cold i.e. in the morning.
The way i see it is that the MAX level, is what it says, the MAXIMUM you should put in the engine and no more
If you fill it up when it's been turned off for a couple of minuites you will exceed this level when you leave it overnight
This is the way i have always understood it.
Please correct me if you think i'm wrong
Dave
Dave
Dave
Dave
Saw you at A1 the other day mate, last wednesday i think, car looks a real beauty, but i agree the darker blue is nicer
I must agree with Dave and Simon on checking the oil, maximum is maximum. Although the oil will drain back to the sump very quickly when its hot so won't make a big difference anyway
Originally Posted by Alvyn
I'm with you on this the other way will cause tooooooooooo much oil contained and WILL blow seals etc and course the car to smoke a lot
You'd probably be suprised at the amount that will still be in the head after 5 mins, this would still cause you to go over the level
HOPE you lot dont ever drive diesil engine vehicles IF over filled with oil they begin to suck it up and run on the engine oil and wont turn off and can rev up full throttle till they go bang
Not much difference between checking when engine is hot but been stood for half an hour OR being left over night and then checked?????
Engine hot, been stood for half an hour --> oil at min mark
Engine stone cold, been stood over night --> oil half way
Didn't fill up or anything like that.
Now you guyz tell me wich is the correct way of measuring???
this is the way I have ALWAYS check how much oil is in the engine from cold so by the looks of yours it HASN'T got enough m8
ps most engine once started up DONT have that much left in sump so d/stick WILL show low
Originally Posted by Speedy G.
So why do you say that I've got too little oil in the Cos.
It's between min and max.
ps: maybe IF your lucky and this was to happens the oil light may come on for a few seconds and YOU would see it hopefully NOT cause n e damage to the engine etc If unlicky b/ends may well start to rumble
[quote="Speedy G."]Then why would there be a min and max my friend????
MIN: is the least oil YOUR engine will fuction with without causing damage(wouldn't do this too many times) MAX: again the most oil you want in the engine for it to fuction correctly.
n e amount of oil between min-max will do if THAT makes you feel better BUT check it 1st thing in the morning and put it to the MAX
