Cracking inner wings
Old May 9, 2005 | 07:35 PM
ImaRacing 700's Avatar
ImaRacing 700
Default Cracking inner wings
Noticed my 3dr is getting a couple of cracks on the inner wings both sides...i assume this is the perils of running hard suspension and a proper strut brace ...Plates are gonna be welded to strenthen.
I remember advising people taht if you run coil overs front and rear you need to strengthen it all up but of course i was talking bollocks Take heed before the cracks to to rust and you ahve to sell it to a breaker for cheap money cause its rotted out!
Old May 9, 2005 | 07:44 PM
Ryan's Avatar
Ryan
its means its been thrashed
Bit of a give away when buying a car to tell if its had a hard life.
3dr's suffer from major chassis flex
Old May 9, 2005 | 07:45 PM
JimRS's Avatar
JimRS
My car that im breaking now is the same, Cracked inner wings
Old May 9, 2005 | 07:47 PM
Deano's Avatar
Deano
Agreed the strut brace has been fitted a bit too late Phil , its supposed to have a brace fitted before the inner wings crack , youll need to put the car on a jig and have the front straightened , thats what Brooklyn told me when I had my first 3 door and the wings had gone
Old May 9, 2005 | 07:49 PM
JimRS's Avatar
JimRS
It hasnt split down the A piller aswel has it?
Old May 9, 2005 | 08:15 PM
ImaRacing 700
It hasnt actually cracked the metal!Only the paint!!!!!
But carry on and it will!!!
So the brace has caught it in time will be strengthened all the same.
One thing i can say it aint a monte thrashed motor you can tell...its the hard suspension that fooks em!..So Ryan go back in your hole with YOUR theories !
Old May 9, 2005 | 08:32 PM
Matt's Avatar
Matt
mine aint split thanks
Old May 9, 2005 | 09:08 PM
Niall.b's Avatar
Niall.b
first sign is usually a small dent on the top edge of the wing, level with the strut turret
Old May 9, 2005 | 09:56 PM
Ian M's Avatar
Ian M
seen plenty of shells fooked through using coil overs without strengthening them first.
Old May 10, 2005 | 01:00 AM
CozzyBrom's Avatar
CozzyBrom
good job fordmotorsport did mine before it was used in anger
Old May 10, 2005 | 07:22 AM
Ryan's Avatar
Ryan
yes its a theory phil. not common knowledge at all
Old May 10, 2005 | 07:46 AM
SPADGE's Avatar
SPADGE
You fitted that wing properly that was tacked on last time i saw that car Phil?
From what i remember that car had seen a fair bit of action which as well as what Ryan said probably was responsible for the cracking!
Old May 10, 2005 | 12:08 PM
ImaRacing 700
to clarify...its only cracked the paint!......but will be strenghthed now i can see what happens.
Hope she was thrashed thats what a cossies for Drives fookin mint for it though...even if every part is gonna be changed
Old May 10, 2005 | 12:12 PM
SPADGE's Avatar
SPADGE
Looked like it had had more hits than the Beetles to me Phil
Old May 10, 2005 | 03:59 PM
ImaRacing 700
Spadge i see your a good judge of a cossie then...atleast this one hasnt blown up yet
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
muzzman1
Sep 30, 2015 08:59 PM
