help 1.8 td timing
Make sure you lock the pulley wheels so as not to lose the pump timing otherwise you'll turn an hour job into an all day job!
If you haven't got any timing pins, mark the pulleys against the cover with a touch up stick (not the most accurate) or you can get away with using the same size bolts as the holes in/through the pulley wheels as they are threaded (if I remember correctly).
slammedorion
15
01-11-2015 07:17 PM
base190380
03-09-2015 08:32 PM
