Air -Air injectors
Old 08-05-2005, 01:08 PM
Tony Ryan
Tony Ryan's Avatar
Default Air -Air injectors
Forgive my ignorance but can anyone give me the correct details of the injectors used in this kit , or is there loads of different types ?? Been offered a spanking set by a very reputable member off this board and dont wish to make a cock up !!
regards
Tony
www.touringcarspares.com
Old 08-05-2005, 03:09 PM
Tony Ryan
Tony Ryan's Avatar
Does no-one know this then ??
Old 08-05-2005, 03:14 PM
GARETH T
GARETH T's Avatar
are you after the older style air injector number or the newer,
if the old i can go have a lookie for you if you like,,,
Old 08-05-2005, 03:48 PM
the strut brace
the strut brace's Avatar
theres a lot of copies tony , i have some bought from steve scott, the number on the side is 0280150785
Old 08-05-2005, 03:55 PM
GARETH T
GARETH T's Avatar
304cc volvo injector
Old 08-05-2005, 03:59 PM
DazC
DazC's Avatar
Oh dear!
Old 08-05-2005, 04:00 PM
the strut brace
well thats what they are and steve scott knows his onions so there
Old 08-05-2005, 04:15 PM
Tony Ryan
Tony Ryan's Avatar
Does it matter that they are fuel injectors then , or should they be the correct Air injectors , whats the number for the other type then , not the Volvo ones, lol.
Old 08-05-2005, 04:17 PM
the strut brace
im lol that steve scott is selling a volvo injector these are the correct air injectors according to him
Old 08-05-2005, 05:14 PM
Billabong
Billabong's Avatar
Fuel injectors use the fuel for lubrication/cooling iirc, ideally you nead a gas injector for non fluid/gas/air applications.
That code IS a Volvo application (2.4L turbo) fuel injector.
Old 08-05-2005, 05:18 PM
the strut brace
it doesnt seem to do his white escoz much harm.......does it???
Old 08-05-2005, 05:20 PM
Billabong
Billabong's Avatar
Strut, I wasn't saying they wouldn't work, just what that part no. is and my understanding of the injector type required for that application - I ain't a tuner, lol
Old 08-05-2005, 05:21 PM
the strut brace
i know mate, im just messin
Old 08-05-2005, 05:37 PM
Tony Ryan
Tony Ryan's Avatar
Can anyone else shed any light on these , thanks strut for your comments, but i could do with a bit more info on Boost control to prevent the expensive mess i already have being repeated !
Regards
Tony
Old 08-05-2005, 05:40 PM
Billabong
Billabong's Avatar
Tony, there was a post a while back regarding air injectors and the merits of using fuel injectors etc. but without the search working, could take some time to find.
Stu & Mike R also do air injectors afaik, so may be able to help??
Ryan
Ryan's Avatar
Tony,
Wightout aka Darren has a set, or Stu @ MSD can supply you with the correct air injectors.
Old 08-05-2005, 05:42 PM
GARETH T
GARETH T's Avatar
been out too look at my set,, but i cant see the numbers on them
Old 08-05-2005, 05:48 PM
Billabong
Billabong's Avatar
If your car is already mapped for air-air then your replacement inj's need to be of the same flow rate or your map may need tweaking I believe....again, Mike or Stu could probably confirm.
Old 08-05-2005, 05:54 PM
GARETH T
GARETH T's Avatar
Billabong,
you are right mate,,, as always
Old 08-05-2005, 05:55 PM
DazC
DazC's Avatar
Correct. Otherwise boost pressures could be well out as the actuator will be seeing a different amount of air than on the old injectors.
Chances are, the fuel injectors will over heat and stick if used as air to air. Stuck open and there will be little boost. Stuck closed and there will be unlimited boost.
Old 08-05-2005, 06:11 PM
dave green
dave green's Avatar
My air to air set up has ford part numbers on them
supplied by A1 rally sport about six years ago.
Dave
Old 08-05-2005, 06:13 PM
dave green
dave green's Avatar
Old 08-05-2005, 06:28 PM
ImaRacing 700
ImaRacing 700's Avatar
LOL @ fuel injectors being used as air injectors NOT RELIABLE...andwhat happens when a injector used for this application fooks up...unlimited boost wernt it?
I supply trade with the PROPER injectors
Old 08-05-2005, 06:31 PM
Ian M
Ian M's Avatar
i think the number you require is 0280150842
Old 08-05-2005, 06:58 PM
Tony Ryan
Tony Ryan's Avatar
Perhaps followed by -850 ?? Seems like ive got to the bottom of this then thanks all that have pm'ed etc..
Old 08-05-2005, 07:03 PM
GARETH T
GARETH T's Avatar
an indy car fuel injector
Old 08-05-2005, 07:04 PM
Billabong
Billabong's Avatar
i think the number you require is 0280 150 842
Isn't that still a fuel injector though? (a 4.5ohm "Indy")
EDIT....too slow
Old 08-05-2005, 07:07 PM
ImaRacing 700
The 842 is a gas injector 1200cc @ 1bar pressure 4.6ohms
Gareth were you get your info? I bring FACTS
Old 08-05-2005, 07:14 PM
Billabong
Billabong's Avatar
But Phil, our American friends call petrol gas.......
Maybe that's why they had problems putting fuel through them then
Old 08-05-2005, 07:16 PM
Ian M
Ian M's Avatar
nope these are what stu sells 1200cc gas injectors.
Old 08-05-2005, 07:18 PM
Tony Ryan
Tony Ryan's Avatar
Well thats 2 people saying theyre the right ones , gotta be a start !
Old 08-05-2005, 07:21 PM
Billabong
Billabong's Avatar
The 785 or the 842? Double check with Stu or Mike, they'll know for sure, although I don't doubt Phil's Bosch part no. knowledge.
Old 08-05-2005, 07:23 PM
ImaRacing 700
Billy yes you fooking do I supply Stu with them
Ok dont beleive me as a Bosch Dealer...ask a non Bosch dealer Wont bother helping in future!
Old 08-05-2005, 07:27 PM
Billabong
Billabong's Avatar
Old 08-05-2005, 07:31 PM
DaveEscos
DaveEscos's Avatar
Phil, can you price me up two please
cheers
Old 08-05-2005, 07:34 PM
Billabong
Billabong's Avatar
is more appropriate I feel.....
, fitted your uprated pump yet?
Old 08-05-2005, 07:39 PM
ECU Monitor Enthusiast
I am afraid to say Phil does know his bosch stuff !!!
Phil, while your on, whats the maximum spin speed of a bosch washing machine ?
Thanks in advance
Old 08-05-2005, 07:40 PM
DazC
DazC's Avatar
Old 08-05-2005, 09:14 PM
GARETH T
GARETH T's Avatar
ImaRacing 700,
the same place as bill it looks
Old 08-05-2005, 09:16 PM
Billabong
Billabong's Avatar
LMAO
Well I guess if people are going to use fuel injectors for air-air applications, some will attempt to use gas injectors for fuel (not directed at anyone on here, Gareth will know what I'm on about)
Quick Reply: Air -Air injectors
